Took z out today to a car show but before I got there put 11 gallons of fuel(premium) car was running perfect got to the car show and car felt like it was shaking at idol ,gave it gas and was sputtering. So I stayed at show 2 hrs left,while driving was sputtering threw out all gears not so bad at high rpms ,has any one come across this,88000 miles,don't know last time fuel filter was changed i know injectors have been changed I can see a rc sticker on them. Cars been running perfect maybe bad gas. Thanks
I am having the same issue, I just replaced the fuel filter and my injectors are good. could be computer chip not allowing enough fuel, the only other thing I can think of is the pumps... any other thoughts?
could be a vac issue, could be fuel. the only way to know for sure is to attach gauges and drive around with them to see what the car is doing
![]() Join Date: Sep 2013
Can not stress enough the need to have the spark plug wire boots filled with Di-Electric grease.
The spark can violently bounce to the cam cover causing the issues you both describe. My car did it the very first week of ownership. Once I filled the boots with the grease the symptoms immediately ceased. the car was idling and running better all the way around. |
Thanks for input guys, tried replacing fuel filter and couldn't do it nut was to tight, couldn't get leverage with jack under car so I will bring to a friends shop and replace it there and see if filter works & try di electric . Thanks I'll keep you guys posted.
![]() Join Date: Feb 2011
I actually bought bad gas this summer...it happens. My symptoms were a hunting idle when rolling to a stop and occasional stalls on the roll. coasting idle stumble at 2600 when transitioning back to the throttle at very light loads. It was weird- I think it was too much ethanol water contamination at the gas station.
#7 | |
![]() Join Date: Jul 2011
SP wire arc-ing also causes EMI emmission, same as a nuke, and solid state sensors and nukes don't play well together...
Ok put new fuel filter and still same problem,next step new plugs,in the mean time I'm letting it run & driving it to get rid of gas so I can put new fuel in to see if this whole time it was bad gas.
#10 |
When taking off in 1st gear it sputters until 1500-2000 rpms,if I ease into gas pedal to reach higher rpms 5-6000 it's fine,but soon as I give it half to full throttle it sputters. Maybe that I'll shine a little bit of light,thanks
