#11 |
you could have the wazoo guys go over it and tell you what it needs before you buy it
#12 |
![]() Join Date: May 2007
I will be glad to help you find someone to look at the car with you.
email me your contact info and I will see what I can do. I am jim@gizmosart.com 443-244-1347 Good luck with your search. Jim |
#13 |
#14 |
they're a bit like allstate...but without all the bs rate hikes
#15 |
I'm in Fairfax and would be glad to assist you.
#16 |
Jagdpanzer, thanks for the assistance and I will definitely let you know, right now the car is in the shop getting the clutch cable replaced. So it should be available to look at next week. Isn't Fairfax a bit of a hike down to Fredericksburg? I'm not terribly familiar with the areas outside of Fredericksburg and Northern Richmond. Thanks again for all the responses, quite the brotherhood!
#17 | |
#18 | |
Just so we know what to look for ![]() I would guess Clutch Slave Cylinder or Clutch Master Cylinder. Clutch Throw Out Bearing requires the transmission be removed. Clutch Start Safety Switch is also a possibility.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-04-2014 at 03:14 PM. |
#19 |
Maybe, that is what the sales person had told me, he didn't seem too knowledgeable about the vehicle.
#20 |
that's a very common theme
