Old 07-03-2014   #11
Default Re: Potential ZR-1 Buyer
you could have the wazoo guys go over it and tell you what it needs before you buy it
Old 07-04-2014   #12
QB93Z
QB93Z's Avatar
I will be glad to help you find someone to look at the car with you.
email me your contact info and I will see what I can do. I am
jim@gizmosart.com
443-244-1347
Good luck with your search.
Old 07-04-2014   #13
PhillipsLT5
PhillipsLT5's Avatar
Wazoo, knows, good hands there
Old 07-04-2014   #14
they're a bit like allstate...but without all the bs rate hikes
Old 07-04-2014   #15
Jagdpanzer
Jagdpanzer's Avatar
I'm in Fairfax and would be glad to assist you.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-04-2014   #16
fiestamateo82
Jagdpanzer, thanks for the assistance and I will definitely let you know, right now the car is in the shop getting the clutch cable replaced. So it should be available to look at next week. Isn't Fairfax a bit of a hike down to Fredericksburg? I'm not terribly familiar with the areas outside of Fredericksburg and Northern Richmond. Thanks again for all the responses, quite the brotherhood!
fiestamateo82 is offline   Reply With Quote
Old 07-04-2014   #17
you'll soon learn that almost no distance is to far to go for another brother of the beast
Old 07-04-2014   #18
Maybe Throttle Cable or Emergency Brake Cable. There is a Clutch Hydraulic line......but that is rarely replaced.
Just so we know what to look for
I would guess Clutch Slave Cylinder or Clutch Master Cylinder.
Clutch Throw Out Bearing requires the transmission be removed.
Clutch Start Safety Switch is also a possibility.
Old 07-04-2014   #19
fiestamateo82
Maybe, that is what the sales person had told me, he didn't seem too knowledgeable about the vehicle.
Old 07-04-2014   #20
that's a very common theme
