#11 |
![]() Join Date: May 2013
Do you have someone nearby that could lend you their wheels for a run down the road to eliminate the possibility of tire/wheels.
#12 |
Great idea
#13 | |
#14 |
![]() Join Date: Apr 2013
Wish I did...
#15 |
![]() ![]() Join Date: Jul 2005
I chased down a vibration for a long time.... Rims, tires, bearings, u-joints.... Switching out the driveshaft and yoke made all the difference. I intend to have my original drive shaft and yoke balanced, and anticipate they will be able to tell me how much off it was. My vibration was bad around 68ish, above or below, it wasn't too bad... Eliminate one variable at a time if you can. Good luck.
Mark Horner President, ZR-1 Net Registry 91 ZR-1 #2016 95 ZR-1 #21 DRM-600, LPE 385 |
#16 | |
#17 |
![]() Join Date: Oct 2004
Knowing what you've been through and have done chasing the issue I'd think your only reasonable diagnostic tool would be to do a ride along with someone or drive along and if you find a car that "suites you" (not meant in sarcasm) at speed, you then take those tires and wheels to your car and see if your car still has the same issues or not. There is no other economical or feasible way to accomplish it.
It would easily be worth a couple hundred mile drive to evaluate another car. You mention before hand the speeds that are your concern or where it's most notable. Have that person pass on to you that his car passes the test he feels and you then do the drive. If his to yours passes the test you move yours to his car and see if the same scenario plays out on his car. Two tire swaps and the diagnostics are done. I would think I'd be interested in doing this with someone that has recent tires and maybe stock wheels or if the wheels are aftermarket that their "hub-centric" because there's a few less hassles although as it's been mentioned there's nothing wrong with "lug-centric" and regardless of the center-bore Corvettes are actually "lug-centric" although it's done on wheels that are very close to "hub-centric"! A good day of driving, lunch or whatever and it's done/over - no more diagnostics. If you only wanted to do the swap one way from a car to yours you wouldn't need a ZR-1, just a C4 with newer tires, stock wheels and "no issues"! Last edited by WVZR-1; 06-06-2014 at 12:27 PM. |
#18 |
With no other candidates (c4, c5, 80s/90s camaro/firebird/bmw/others?) to swap a pair of tires (might as well do one end at a time) you could just put your donut spare on one corner at a time. Pain in the butt but will narrow down to which tire or is it the car. So if you move the spare to all four corners and still have the vibe, it's the car.
I get *maybe* 200 miles out of a hub. *Any* hub. It's not the mileage, it's the history. Forget hub centric, if your lugs are correct and torqued correctly they hold the wheel through much more abuse (see 200 miles on a hub if I'm lucky) and my competition wheels are lug centric only. Have you had an alignment, did the tech notice one corner needing or having a lot of adjustment range taken up? You could have more than one bent wheel, in either or both sets too! HTH, - Jeff Last edited by batchman; 06-06-2014 at 01:16 PM. |
#19 | ||
![]() Join Date: Dec 2003
May also be a worn front yoke or worn tail bearing/bushing allowing the yoke to oscillate. Over-tightened front C-beam bolts can cause the bearing/bushing to incur accelerated wear. Suggest: 1. Check with the previous owner to see if the driveshaft has been removed, or 2. Use 2 post lift, in neutral, turn the tires & check driveshaft run-out near both front & rear u-joints and in the middle. 3. check for excessive movement of front yoke. If noted, will require removal to determine if yoke, bearing/bushing or both are a fault. If the yoke is to be replaced, contact Bill Boudreau at www.ZFDoc.com. The correct Spicer yoke can be difficult to find. Bill can tell you the difference from a commonly available yoke which is not quite right. Quote:
None of the above checks will be difficult or expensive and may help to eliminate a distinct possibility. Looks like you have been through the wheel/tire possibility pretty thoroughly. Good luck.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 06-06-2014 at 02:38 PM. |
#20 |
Well - haven't driven it yet - but I took wheels off again and applied a strip of the airplane aluminum tape around the inside of the wheel bores. Stuff was only a couple thousandths off if that when I measured the inside after tape vs the hub. Hopefully...
Pulled on the rears at 12/6 and 3/9. There is maybe 1/16" movement in both at the outer edge. Good, bad, can be tightened with the nut??? Spun the fronts and tried to look across the top of the tire aligning with a washer edge on the inner fender. They look to be pretty round - just the slightest hint of difference. Once again thats the eyeball method which is what I have.. They do not appear to have any sideways runout at all. On the driveshaft deal - would that cause a steady vibration or a harmonic one? This is steady. Does it even if I put in in neutral and let it roll. I understand the shaft is still turning but the pressure is off it. I and the mechanic checked it when it was on the lift and could not find anything even remotely loose. Can't find the PO - the guy I got it from got it at auction and didn't do anything to it other then let it sit in his garage. Alignment is a possibility - haven't gotten with the local guy here to get it on the rack yet. Measured with a tape and boards like we do on the circle track car and appears to be close - although I know that is the "redneck method".. Will drive it tomorrow to a show - see what it does then. I have to get ready for dirt racin tonite... If this stuff don't work maybe I just need to suck it up and make a 5 hr trip up to see the FBI gang and swap wheels with one of them... Thanks all and will let you know.. |
