Old 06-06-2007   #1
zr-1assassin
zr-1assassin's Avatar
Default where does your oil pressure sit???
i would like to know where all your oil pressure needles are sitting on the guage. mine is almost all the way up when i first start it(cold) and then after it warms up a bit it drops to a little above half way. is this normal?
zr-1assassin is offline   Reply With Quote
Old 06-06-2007   #2
Jeffvette
Default Re: where does your oil pressure sit???
That is normal.
Old 06-06-2007   #3
Hammer
Hammer's Avatar
Talking Re: where does your oil pressure sit???
Normal here too.
Old 06-06-2007   #4
Z Factor
Z Factor's Avatar
X 3
Old 06-07-2007   #5
zr-1assassin
thanks guys.....set my mind to eas
Old 06-07-2007   #6
carter200
carter200's Avatar
make it 4 yeps
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 06-08-2007   #7
RedSled
Same for my long run to BG... - Keith
'90 Red/Red #1383
RedSled is offline   Reply With Quote
Old 06-09-2007   #8
bldavis11
Mine always stays high! ?? I've checked the oil a million times and it's always 3/4 between fill and full. Do I have a bad sensor?
bldavis11 is offline   Reply With Quote
Old 06-11-2007   #9
swaindm
Make that another yep!
swaindm is offline   Reply With Quote
Old 06-12-2007   #10
bldavis11
Mine does come down to 1/2 gauge when at idle. All other times it's about 1/8" from the top line.
