Old 05-26-2014   #221
Default Re: Locobob's Interior Mod Thread
1990:
Old 05-27-2014   #222
Schrade
Originally Posted by Locobob View Post
Click on the pic below to see the video
Work is looking good.
Mine is '90; same lights as Jeff's.
Does your console buckle out from under the center trim? What are you doing on it?
Old 05-27-2014   #223
Locobob
Thanks guys, looks like no bulb test mode on ABS active, low coolant and low oil. Although I've seen low oil flash on briefly at key on, possibly just a momentary reading from the sensor under certain conditions?
Console buckle? Are you referring to the drivers side console carpet/side panel?
Robert
Old 05-27-2014   #224
That would be my guess
where did you get the custom DIC panel from?
Old 05-27-2014   #225
Schrade
Yeah there Rob; seems more common than I thought, but only post I saw here on it ever was someone just put screws through the panel...
Even Black screws in Black carpet? Not for something interior...
Old 05-27-2014   #226
Locobob
I'm having it made, don't have the final one yet, hopefully it'll be done today.
Robert
Old 05-27-2014   #227
Locobob
Yeah I have that issue too, might try some Velcro, we'll see when I get to that point.
Robert
Old 06-03-2014   #228
Locobob
So my custom DIC display with integrated tire pressure monitoring system is finished.
Here is the modified DIC housing, I cut a big chunk of it out and then glued a flat piece of acrylic down to provide a flat base for mounting the TPMS. I used some squared plastic tubing for columns underneath to set the height and get it even all around.
These are the component parts that go on top, guts of Orange Electronics TPMS, piece of orange tinted acrylic to bring the display colors more in line with the existing dash lighting, tinted cover panel with warning indicators and a clear section cut out for the TPMS display, and to the right are buttons I made which protrude through the panel in order to activate the micro switches on the TPMS unit.
Here is most of the unit assembled with screws at the four corners to keep everything together. I'm using red LED's for the warning lights. The cord for the TPMS unit will come in through the bulb socket directly left of the unit and then loop around through the far left cube and plug into the unit. I could have added one more warning light at the top left of the TPMS but couldn't really think of anything else I needed. If I still had the factory steering wheel and airbag then this is where the inflation rest warning would go, or if it were a 90 one could put the full power indicator here.
A few parts that didn't get used. First run of the display panel which was way to transparent, clear plastic rod which I cut pieces off and painted to form the TPMS display buttons, and some buttons I robbed off a junk stereo which I was going to use but then realized that doing so was going to cause assembly/dis-assembly issues so I scrapped that idea.
The assembled DIC
Ill get some pics of the unit in action in the next few days.
Robert
Old 06-03-2014   #229
What TPMS kit is it?
Willing to make more of the DC displays?
Old 06-03-2014   #230
LB,
Your DIC display would be perfect for readout coming from a WB O2.
