Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 06-02-2014   #31
QB93Z
QB93Z's Avatar
Default Re: Save the Date - WMD - Saturday, 31 May 2014
Originally Posted by JFFerner View Post
Thanks for the time and effort you put in helping me yesterday. The "Infl Res" light is still off and hopefully will remain that way. I owe you additional thanks as the problematic "Service Ride Control" light is also off now. Rethinking the actions taken yesterday to tighten the very loose left front shock & sensor, somehow I recalled having read about a similar elusive solution to a similar problem. Bingo, we may have over tightened the nut holding it in place. I backed the nut off about 45 degrees, tried it and it worked.
Before I watched you taking the assembly apart, I didn't have a clue how these things came apart, let alone how they would go back together.
I look forward to further participation in Wazoo and your friendship. Come visit us'n in the Mountain State and I'll personally introduce you to "Mountain Mama".
And so it goes.....
Jim Ferner
I am glad that we were able to help. Good job correcting that LF shock sensor.
When we removed the Tech 1 from your car, the adapter must have stayed on the ADL connector under your dash. If you get a chance, please take a look and see if it is there.
Thanks, I look forward to getting together again soon.
