Old 05-29-2014   #11
Tyler Townsley
Default Re: Removing Transmission
Take out one of the transmission bolts and go to a hardware store and buy 2 bolts at least 2-3 in longer and cut off the heads. When go to reinstall put these bolts in the top of the bell housing. Use them like 2 rails, you can use them to get the trans in place and see if you are parallel when you push the trans in place, Another trick is if it hangs on the pilot bushing just put in the clutch, this allows you to wiggle the trans and clutch to get the alignment correct. Once you get up tight remove the bolts and put in the stock bolts.
Tyler
