#61 | |
![]() Join Date: Oct 2013
![]() That's all I thought we were doing here,,benchracing and having fun. ![]() ![]() |
#62 | ||
![]() Join Date: Nov 2007
![]() ![]() Quote:
#63 | |
![]() Join Date: Jul 2005
![]() I still think Pete could cut quicker times with 4.30's, or 4.56's (depending on tire). As he says, the 4.10's got him a 1.59 60ft. time, that's phenomenal, and a big advantage in the Qtr. A .15 advantage in the first 60ft. is several car lengths in the traps. You don't lose that much, (maybe a fender), during the 3-4 shift. That tells me that the 4.10's are not too much gear, but not enough. The reason his times got slower is not the third to fourth shift, but because he wasn't peaking out to 7,400-7,500 in the traps. The trick is getting the great launch AND peaking at the right rpm in the traps. I see the stock gear as a disadvantage at launch. If he cuts 1.74 60 ft time with 550+h.p. and a stock gear, and I cut a 1.76 with 4.10's and a stock motor. How is that using all that horsepower that he's spent so much time and effort building? Just sayin' ![]() More gear, more tire ![]() |
#64 | |
![]() Join Date: Jul 2010
Yes, bench racing is what we are doing here, and it's fun, so long we bring the Scope. |
#65 |
I don't agree. You don't have to go to a block and pulley analogy to explain it. Just look at 60ft. times.
If a ZR-1 cuts a 1.50 60ft., and another cuts a 1.60, who's accelerating harder? The ZR-1 with 4.10's will cut a better 60ft. every time. All other things being equal. |
#66 |
I was told by someone who raced SuperStock for many years that a smaller gear absorbs more energy than a taller gear and so wheel spin is easier to control.
You need more rpm to turn the wheel once w a smaller gear. |
#67 |
The shorter gear actually allows you to apply more rpm, thereby more torque to the wheels at launch. Gears don't literally absorb energy.
It's really about leverage. Short gears give more leverage, but require more rpm to do it. The ZR-1 develops it's power at a higher rpm, therefore requires shorter gears. Last edited by Bob Eyres; 05-26-2014 at 10:34 AM. |
#68 |
Someone mentioned that a 4.10 gear isnt worth it for a 1/4 mile run based on the addition of a shift, and not trapping at peak power.
Then someone mentioned that the 4.10 may not have neen enough gear, perhaps a 4.30 or 4.56 is in order? I would agree with that. So long as you can hook, your 60ft will decrease which will help 1/4 mile times. This is true because of the extra torque applied at launch, extra Force. This decreases as you move off the line as the engine approaches and passes peak power. I had a drag vehicle that made peak power at 4800rpm. With 3.08 gears it would trap the 1/4 mile at 5500rpm in 2nd gear. Swapping to 4.10 gears allowed for a trap rpm of 5000rpm in 3rd gear. In this experience 60ft et dropped, 1/4 mile et dropped, but 1/4 mile speed also dropped 3-4mph. Torque=Rotational force at any moment Power=(Torque(lb/ft) x rpm)/5252 Acceleration=Change in velocity over time Work=force which acts on an object which results in a displacement, if you push on a car with a force of 100 pounds, you are expending energy through your muscylar effort, but if the car doesnt move, no work has been accomplished Work=Force x Displacement Mass=Vehicle weight We also have to remember that when we shift from 4th(1:1) to 5th(0.75:1), or lets say the driveshaft rpm is 7,500rpm in 4th gear with a 7500 engine rpm in 4th, the same 7,500engine rpm becomes 10,000 driveshaft rpm, in 6th 0.50:1 would be 15,000rpm. Some of the newer transmissions (TR6060) have less split from 4th to 5th, which helps reduce that nose-over feeling that some experience when shifting to OD. Engine torque=400lb/ft Rear Gear 3.45:1 Engine Torque x trans ratio x rear gear=torque applied to ground 400x2.66x3.45 =3671lb/ft 400x1.80x3.45-2484 lb/ft 400x1.30x3.45=1794 lb/ft 400x1.00x3.45=1380 lb/ft 400x0.75x3.45=1035 lb/ft 400x0.49x3.45=676 lb/ft SO throwing a 4-5 upshift losses 345 lb/ft of applied torque combined with the fact that at this speed aerodynamic forces are increasing, thus adding to negative acceleration. Fascinating discussion, so many variables. With the extended rpm potential of the LT5 conventionally agressive gearing, isnt so agressive when used with the LT5. |
#69 | ||
![]() Last edited by Schrade; 05-26-2014 at 10:35 AM. |
#70 | |
My point was, that just because your tach reaches 7500rpm quickly, doesnt mean that your speedo is accelerating as quickly. I agree with your drag scenario a car cuts a 1.50 60ft, and another hits a 1.6 60ft. The 1.5 60ft is accelerating harder. I also agree, a 4.10 geared ZR-1 will cut better short times(60 ft) than a higher geared ZR-1, all else equal. Now I ask you this, in your scenario ZR-1 #1 cuts a 1.50 60ft with its 4.10 gear, and ZR-1 #2 cuts a 1.60ft short time with its 3.45 gear. Which ZR-1 will trap with the higher Speed MPH? All else equal. |
