Old 04-22-2014   #1
Default New Aluminum Flywheels & Ram Clutches
http://jerrysgaskets.com/store2/root...ee9a2385954ce4
We have finally expanded our listing of Ram Clutches for the ZR-1 and added 2 new aluminum billet flywheels, with some features not offered by any other manufacturers, features that I believe, offer better and more options, relative to a ZR-1 owners preferences and needs.
The new flywheels are custom made exclusively for Jerry's Gaskets, PN's 10202537 & 10202538.
Many different clutch options at prices competitive with Summit & Jegs. We will be adding more, stock replacement pull release style clutches, as well as a hydraulic push-release style, compatible with the dual mass flywheel and our new aluminum flywheels mentioned above.
Your feedback is welcome and appreciated.
Old 04-27-2014   #2
Default Re: New Aluminum Flywheels & Ram Clutches
If you just need to replace the disc, with the dual mass flywheel & stock pressure plate, you can use either one of these clutch discs.
http://jerrysgaskets.com/store2/root...roducts_id=874
or
http://jerrysgaskets.com/store2/root...roducts_id=886
Old 04-27-2014   #3
Fantastic! I know I will be going down this road sooner or later.
Thank you for helping us keep our Zs running.
Old 04-28-2014   #4
batchman
And thank you for doing a *great* job of laying out the options in a sensible fashion.
I keep wondering though how the pedal effort is with the Ram stuff especially converting push/pull, which new for this year my rules package will allow!
Cheers,
- Jeff
Old 04-28-2014   #5
Scott, one of our WAZOO gang, had Mrac install Ram clutch. I believe some mods were made to Ram kit to work with OEM dual mass flywheel.
His thread indicates Ram set up feels as good, if not better then, OEM.
http://www.zr1.net/forum/showthread.php?t=22736
Old 04-28-2014   #6
Nice Jerry, glad to see some more options
