#11 |
![]() Join Date: Apr 2004
The oil cooler is sandwiched between the rad and ac condenser, follow the lines to the connection at the cooler has two line with a single bolt to the connecting block it is replaceable as a set,
http://www.ebay.com/itm/like/291012080282?lpid=82
#12 |
I just looked at my lt5 service manual on how those lines ran and it looks like if they're leaking at the oil cooler it's going to drip down onto the coolant lines.
#13 |
![]() Join Date: Jan 2009
The most common point of leakage on the OEM hoses is at the connection ends where the metal contacts the rubber hoses.
#14 | |
Make sure you have the right wrenches handy as those fitings are over an inch in size. if I remember correctly 1-1/8 and 1-1/4 are needed. Those sizes are not in everybodies tool box. I suggest the steel braided replacement option.
#15 |
Put new oil cooler lines on. While it was apart replaced the lower radiator hose it was really spongy and seeping. Got everything back together no more leaks. The car runs great. The service ride control light went off on its own but now my change engine oil light is on. Is there an easy way to turn that off?
#16 | |
#17 |
Owners Manuel 101,
Key on press ENG/MET with in 5 sec press again within 5 sec press & hold range button Change oil light will flash Hold range button until is stops flashing.
#18 | |
![]() Join Date: Nov 2013
#19 |
Much appreciated!
