Old 04-02-2014   #1
John Boothby
John Boothby's Avatar
Default Fuel system decarbonizing
Has anyone out there ever had their fuel system decarbonized?
I just saw a demo on TV regarding this. I guess it is a new proceedure that can be done in about an hour. It involves hooking up a machine to the fuel rail and running a highly refined fuel through the system under about 40psi.
The machine uses a "Nano-reactor" to atomize the fuel before it enters the fuel system. It also gives it a negative charge. The carbon has a positve charge so it attaches to the fuel molecules as it leaves the engine.
It kind of reminds me of the old quack medical machines of the past. That is why I ask the question.
Old 04-02-2014   #2
USAZR1
USAZR1's Avatar
Default Re: Fuel system decarbonizing
De-carbonizing your wallet,maybe.
USAZR1 is offline   Reply With Quote
Old 04-02-2014   #3
Snake oil
Old 04-02-2014   #4
PhillipsLT5
PhillipsLT5's Avatar
I de carbon mine every weekend with my right foot & permagrin
Old 04-02-2014   #5
John Boothby
Here's the demo I saw.
http://www.youtube.com/watch?v=sKTp2DjugOA
Old 04-03-2014   #6
Have to say the demo with the measurements at the end does seem convincing enough to make you want to try it and see for yourself.
Old 04-03-2014   #7
Mechanics have been using ATF or just plain tap water to clean carbon out of engines for years! AND, as I inadvertently discovered when I developed a coolant leak while doing a 1/4 mile pass, coolant will get everything sparkling clean as well - I mean it looked like a never run engine!
Ever wonder where the phrase "blowing smoke up your ***" came from?
Blowing smoke...
Old 04-03-2014   #8
Schrade
Blowing smoke...
I've heard of spraying water into the intake to boost the squeeze in the holes (while you're spraying the water), and break loose deposits, but never seen any before and after shots showing effectiveness - or even video showing what comes out of the exhaust.
Might be interesting to try it and see, with a cam recording the exhaust.
Anybody tried water spray? See anything?
Old 04-03-2014   #9
John Boothby
They used to use water injection in aircraft engines for years both in recips and the early jets during takeoff when they needed max power. Not new. They also used alcohol injection in recips.
Old 04-03-2014   #10
mike100
just like any blown head gasket or intake leak- it's a big steam clean job.
