02-22-2014 | #1 |
Stainless Works headers
I am installing SW headers on a 90 Z and the pass side header has a 1/2 inch male quick connect air fitting welded on #2 cylinder. Whats that for ?
Also... do I need to lift the motor a little to change the oil pan gasket? If so...one side or both?
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black |
02-22-2014 | #2 | |
Removing Oil Pan Engine In Car
Lift the front of engine a bit (remove two motor mount nuts) to get those three (90') or four (93'-95') front 6mm oil pan bolts out. Some remove the cross boxes. Engine lifted in front with 2x4 wood spacer in place. Oil Pans and Gaskets Differences TIPS Installing New Oil Pan Gasket New Oil Pan Gasket and Bolts Oil pan gasket
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-22-2014 at 03:14 PM. |
02-22-2014 | #3 |
Re: Stainless Works headers
Installing on Ã* friends Z, sw headers and B&B exhaust.
Made with M10 thread on the inside and screwed in a stainless bolt. At Jerrysgaskets.com you can find a good installation guide for the oil pan gasket. Or just follow the links from Dynomite , I use them quite often too. Last edited by Jitse; 02-22-2014 at 04:33 AM. |
02-22-2014 | #4 |
Thanks...
