02-11-2014 | #31 | |
Re: 1991 Zr-1 Stumbling off idle
Schrade - It seems to smooth out a bit in the 1,200-2,000 range. By abrupt, i was trying to convey that when you ease into the throttle as if there is a cracked egg under it and you don't want to crack it more it is pretty smooth. Stumbling starts by applying the throttle any more quickly than this i.e. - letting the clutch out and applying throttle to start rolling. I'm not talking about ripping off any 0-60 runs by any means. CEL is corrected thanks to suggestions on here - folded pin on dis. |
02-11-2014 | #32 | |
02-11-2014 | #33 |
If slow gas pedal (as opposed to quick), reveals no irregularities, I have no ideas about the original issue - the stumble that you have...
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
02-11-2014 | #34 |
Enginerd,
If the car had 60k on it w original injectors, I would suggest changing the in-line fuel filter, if you haven't done so already, and then check the fuel pumps for a few things. 1) the plastic clamps connecting the hoses in the tank should be replaced, 2) change the pump "socks". Frankly, I'd swap out the pumps to Bosch rotaries while I was at it or the Suburban pumps if original. Also, you need to check fuel pressure under load so a setup like Paul's will help doing that.
02-11-2014 | #35 | |
This post was made right after I had seen the same issue. *********************************************** Date: Thu, 20 May 1999 14:48:16 -0500 Reply-To: paul.smith@AMD.COM Sender: "ZR-1 Corvette enthusiast list." <ZR1NET@HOME.EASE.LSOFT.COM> From: paul.smith@AMD.COM Subject: Re: [ZR1] Plenum Removed To: ZR1NET@HOME.EASE.LSOFT.COM Content-Length: 3819 Status: RO X-Status: $$$T X-UID: 0000001160 Be very careful plugging in this connector with the 1/4" bolt. Do not force it into the socket!!! You can bend the pins on the ignition module very easily. I found a bent pin on one that I took apart recently. It helps to have very small hands :-) Paul Smith '94 #207 Admiral Blue/Black KUL ZR1
