#11 | |
Matters only that you're THINKIN'. And readin' it. ![]() Thinkin' is ALWAYS good. It's when stuff comes to ya'... And I wish some of you guys would read and feedback on the other post #218 in the Throttle Hesitation thread. _____________________________________________ ...and I'm still thinkin' on PCV oil pullin' through the burn... Marc acknowledged that a LOT of oil does come through the PCV. The plenum has a depression right at the PCV inlet port, where the oil collects (Primary butterfly location of course has a little to do with that). And isn't the Charcoal Cannister purge port right next to PCV port? Do the fuel vapors facilitate vaporization of the oil? Is Duty Cycle of CCP longer and more frequent in LT5, that other GM mills? If one uses lighter viscosity oil, then oil is gonna' more readily vaporize, and more readily pull from the crankcase, through PCV - correct? An ACCURATE oil level is imperative too, since too much oil gets foamed up by the crankshaft spinning through it??? __________________________________________________ _ Do oil catch cans have to be emptied? If so (or even if not), could a check valve be integrated into the can, to allow the accumulated oil to be purged through CCP? Could CCP Duty Cycle be re-coded to accommodate this??? Last edited by Schrade; 01-27-2014 at 03:21 PM. |
#12 |
Here is what I am thinking
![]() Just Do It. But in this case Do Not DO IT ![]() PCV System TIPS Do use an oil catch can ![]() See item#5. LT5 Added Systems Details for Oil Catch Can Installation Say Schrade........tell Daryll (GC) I am in Kauai Hawaii today. He is always wondering where I am. ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-27-2014 at 06:25 PM. |
#13 | |
Hawaii. Pffft... Not enough Global Warming in SD??? ![]() Last edited by Schrade; 01-27-2014 at 08:02 PM. |
#14 | |
10 below zero this morning in SD ........70 in Kauai Hawaii. ![]() |
#15 |
what I have found with my 2 cars if I run the oil level right at the add line .I burn about 1/2 qt in 3000miles . when I first got both cars I ran the oil level all the way up and had to add oil about every 1000 miles . jmho
#16 |
![]() Join Date: May 2013
I was wondering the same thing as I used to do that in my other vehicles for that very reason but since some newer cars have oil level indicators and warranty stuff I stopped. I don't think my 90 has a oil level indicator in the crankcase or does it?
#17 |
my 90 doesn't but my 92 does . filling the way I shared I have never had the low oil level light come on in the 92. I have cked it to make sure it still works . I have been changing the oil in both my zr1s this way for almost 120k miles. yes I drive both cars as much as I can .lol what I do when I change the oil is put in 7.5 qts start her up for 20 seconds . then the next morning add what ever I need to to bring it up to just above the add line . usually it isn't very much at all maybe 1/3 qt
#18 | ||
Experimentation and new stuff [ideas] ! Looks like a summation of just about every one of my posts there Mr. P!
====================== So to get back on topic here, and not boost my own thread ![]() Problem is oil fouling the burn. Objective is filtering the oil / fumes, sans the 'old' way (catch can). PCV SOURCE air comes in from IN FRONT of the TB butterfly. PCV purge is BEHIND the butterfly. With 2 LARGER vacuums 'feeding' (??? ![]() And how much vacuum is necessary to maintain purge? If only a nominal amount is necessary, then we REDUCE the source ports, move the purge up front of the air filter, and increase the line size enough to maintain pressure differential. Thoughts? Opinions? More ideas here? Always thinking; experimenting ... ![]() |
