Old 12-10-2013   #1
5ABI VT
Question Looking for info on gears! Where to buy? Brand and type? Diff rebuild?
I've heard people using the viper rear gears and just want to do it right. I wanted to ask about rebuilding the diff etc and where to buy parts for that as well?
Looking to go 3.92 if offered if not 3.73 and wanted to start gathering the necessary parts.
Old 12-10-2013   #2
Default Re: Looking for info on gears! Where to buy? Brand and type? Diff rebuild?
Here is one choice, I had Marc change mine to 3.73 while it is at his shop.
http://zr1specialist.com/HAT%20Web/products/gears.htm
Old 12-10-2013   #3
WVZR-1
I understand you need to be careful with the 3.9+ gear sets these days. It seems that these are now offered in a "multi-bolt" ring gear to accommodate the 3/8 and also the 7/16 later style MOPAR ring gear. I don't know that it should be an issue but it's something to ask going in. You certainly wouldn't want a 7/16 later style "only" gear set. The Corvette is a 3/8 ring gear. You would want a 226mm ring gear also. That's outer ring gear diameter, the Corvette was only offered in the 216mm gear. Sometimes with a 226mm ring gear the housing needs massaged a bit for the install. Often times not.
If you were interested in doing a complete build I have NOS/GM housing and then you could either shelve the 3.45 or sell it as an assembly. I've new short-axles also and a Dana brand new differential. I have a 3.73, 3.54 and a 4.10 gear set all new GM or Dana brand. I don't have a 3.9+ gear set.
I believe you use a USA "drop to" address so the ship wouldn't be an issue. If you're buying maybe it would be wise to check local first. You can't ever tell what someone has on their shelf or in a warehouse that could be negotiated for a sale. If there's a Dana/Spicer drive-line dealer/jobber in the area I'd start there. Just make sure they understand Vette/Viper D44 sometimes referred to as D44-HD. There's a D44 also that is not the correct stuff.
A 3.73 gear requires only the change of the driven gear for speedometer correction. An advantage? In you particular case I wouldn't think so. You do need to be sure you have the speedometer correction gears when you do the job. It's then a "once and done"! Marc is the "go to" for them regardless of where you buy the gear kit.
Old 12-10-2013   #4
this is the one I bought
http://www.justdifferentials.com/D44...4hd-411-oe.htm
Old 12-10-2013   #5
WVZR-1
Is it already installed?
Old 12-10-2013   #6
Yes I have had it in the car for about 1 year.. no issues so far
