Old 12-02-2013   #1
92whiteZ
Default "Service ASR" & 'Service ABS" lights
My Z has started a strange habit of turning on the "Service ASR" & "Service ABS" lights on every so often. Its only while I am out driving it and it isn't every time. Upon initial start up the lights go through their normal check and then stay off until something goes funky and the come on.
Turn the car off and after restarting the lights are off. They don't always come on and havent been able to reproduce them coming on under controlled circumstances.
Is this an indicator something is about to go out? I have a Genisys scan tool but honestly doesn't read the OBD 1 cars that well. need to save up for a Tech1. Have not pulled any codes as I haven't had the scan tool connected when the lights have come on.
Anyone experience something similar?
thanks
92whiteZ is offline   Reply With Quote
Old 12-02-2013   #2
Default Re: "Service ASR" & 'Service ABS" lights
thanks
Easy things first... Check your brake master fluid level
Old 12-02-2013   #3
92whiteZ
yeah I looked at that too. I recently flushed all the lines when I put on the GS calipers, new pads & rotors. So the master cylinder is full.
And this just popped up, I had a few hundred miles on the new brake set up before the lights started coming on. unless I somehow have an air bubble that was hiding in the system that found its way to the abs controller....
that's why i find it slightly odd.
Old 12-03-2013   #4
Thats entirely possible (Air in the system) I suggest a good bled of the system again to just rule that out. Ive done your exact brake setup on my car and nary a problem.
Old 12-03-2013   #5
Schrade
Have you moved the Spark Plug Wires recently?
If they're mis-routed, they can emit EMI - same as a nuke, and solid state sensors and nukes don't get along. (me either - I'm fresh out of SPF nuclear strength)
Old 12-03-2013   #6
92whiteZ
these are all good tips. thx
I have not moved the spark plug wires recently. I did change the plugs but didn't put new wires on. and it appears all the OEM wire looms, etc are still in place.
I will tinker with it this weekend and see if I can consistently recreate the problem.
Old 12-03-2013   #7
Jagdpanzer
Jagdpanzer's Avatar
Are all your tires the same diameter?
Had the same alarm lights trip on my 94 when taller rear tires are installed.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-09-2013   #8
92whiteZ
So I did some experimenting this weekend. Under normal driving conditions the abs/asr lights stay off. Even under moderate braking. But any big braking where the body shifts heavily to the front, the abs/asr lights illuminate and even the brake light in the gauge cluster will illuminate briefly. Like the fluid is sloshing around in the master cylinder, uncovering the sensor. The MC is full with fresh fluid.
Am I correct to presume there is air trapped in the system? I just bought a tech 1a. Is there a means of cycling the abs controller to help move fluid through it?
Once the tech 1a arrives I will pull the codes. What is interesting is the lights dissappear every time the car is turned off. And stay off until I make a hard braking move where the weight shifts forward.
I am running shelby wheels which what I presume are correct
+1 sizing.
Thoughts?
Old 12-09-2013   #9
Schrade
I am pretty sure that if there's air in the MC, it CANNOT be cycled down the lines, to purge. I THINK the lines have to be dis-connected to properly purge air from the MC, and AFTERward, the air that might be in the lines. Could be wrong tho here'... I think 2 tubes should be connected to the MC OUTputs, back into the MC reservoir.
Did you get di-electric grease in the SP wore boots? This high energy ignition system will readily discharge EMI, if ANY resistance is encountered, I do believe here.
Old 12-10-2013   #10
92whiteZ
When I flushed and bleed the brakes I used a snap-on brake machine that has vacuum lines attached to the bleeders and low pressure at the MC with fluid. I don't think any air got trapped in the MC but who knows.
I did change the plugs recently and have yet to put dielectric grease in the boots. will do that this weekend. that's a good thought, thanks!
I am prob just stuck bleeding the system again. just wanted to check and see if this was similar to anything someone else may have dealt with.
thanks everyone!
