#311 |
Key ON, pulled IAC, cranked it, and it went to 3k rpm.
#312 |
#313 |
![]() Join Date: Nov 2011
#314 |
![]() Join Date: Dec 2003
Don't pull the IAC valve, only the electrical connector to the IAC valve. With the IAC valve removed, you have opened a large bypass around the throttle body.
#315 | |
(I had a feeling that's what you were getting at there Steve ![]() I should have said that I pulled the IAC CONNECTOR... Last edited by Schrade; 12-01-2013 at 05:58 PM. |
#316 |
OK, seems like that would be an easy mistake to make. I thought about rereading the whole thread, figured it must have already been mentioned, but it's a loooong thread.
#317 | |
I cannot get an Allen head in that Min Adj stud either... I did get a 5/16" on the nut, and got it backing out ATM. |
#318 |
Put a phone book over the TB extension - a hiss started, then got LOUD...
#319 |
Found it. Right [near] the FPR vacuum connection to the plenum.
(turned out to be the plenum-to-PCV cap connector. It had a zip tie, and I hadn't replaced it) Can't hear it too well in the vid; I tried to get the hose near the mike in the cam, but when I held the hose to my ear, it almost pulled out my brain cells. All 2 of 'em ![]() http://www.youtube.com/watch?v=Hw0mfEs8bLk So now, it's still idling with a 150rpm swing, 775 - 925... An IRREGULAR lope. Last edited by Schrade; 12-01-2013 at 06:00 PM. |
#320 | |
START motor, then let it idle down. What happens? Still surging? Also, if you unplugged IAC, you should have done an IAC reset after plugging it back in. |
