Old 11-30-2013   #1
bamawrx
Default INFL RST fix PHOTOS ADDED
I've read the TSB and technical post on this forum about this issue. Does anyone have a link with any photos or diagram about the K pin? Or photos of any portion of this process that would be great.
I'm looking for more details before I tear into it if possible.
2011 Carbon Edition Z06 #225
1990 ZR1 #88
bamawrx is offline   Reply With Quote
Old 11-30-2013   #2
Z06scentair
Z06scentair's Avatar
Default Re: INFL RST fix question
Third from right on the bottom row.
Old 11-30-2013   #3
ghlkal
ghlkal's Avatar
I'm having problems accessing my photobucket, but I _think_ this image that I found is correct for the ALDL connectors ...
(Just where Z06 said it would be :-)
Old 11-30-2013   #4
bamawrx
Thanks guys. I'm going to take a look at it tomorrow. See what kind of code I get. If anyone finds any shots of any portion of this operation I'd love to see them.
1990 ZR1 #88
Old 12-02-2013   #5
http://www.zr1.net/forum/showthread.php?t=8315
Old 12-02-2013   #6
bamawrx
Step One:Remove side panel. Leave tire and wheel well in place.
[IMG][/IMG]
Step Two: Remove Battery
[IMG][/IMG]
Step Three: Remove battery platform. Only 4 bolts and allows unfettered access to frame/sensor.
[IMG][/IMG]
Nasty under the sensor.
[IMG][/IMG]
Step four: All cleaned up. Dielectric grease added and re-attached sensor next.
[IMG][/IMG]
Success! First time my idiot light screen has looked like this.
[IMG][/IMG]
To clear the code required the use of a stop watch. Counting was not precise enough for this system. Have jumper wire from K pin to ground on the seat frame when you turn key to acc. Hit the start button on your stop watch and remove wire from ground THE INSTANT the INFL REST light blinks on dash. Watch the timer and reapply ground wire when it hits 3 sec, and pull off when it hits 6 sec. Done.
My guess is the difficulty everyone has with this step is the level of timing the system is demanding. Get the time right and its easy. Maybe this will help some people in the future. It was a fun job to do.
TIPS: Use a torx bit in a socket driver to remove two small torx screws inside bottom of wheel well. This avoids having to jack car and remove wheel. These two screws attached to the side skirt, which you will need to be able to flex out of the way to access a bolt on the bottom of the side panel.
Solid copper wire for jumper is great as it will stay in pin K location freeing up your hands.
1990 ZR1 #88
Old 12-02-2013   #7
Z06scentair
Assuming you had a code 16? Thats the easy side, now you should go ahead and do the passenger side just to be safe. I recommend removing at least the rear portion of the wheel well. It's a FUN job.
Congrats on the Drivers side!
Old 12-04-2013   #8
bamawrx
For some reason I'm remembering the code as 26. Two long blinks and six fast blinks. So far so good. I will start reading on the other side and may dive into that soon. I did enjoy the small job, very satisfying.
1990 ZR1 #88
Old 12-04-2013   #9
Excellent photo coverage there bamawrx
The step by step is easy to follow
Old 12-09-2013   #10
WydGlydJim
WydGlydJim's Avatar
The sequence of the timing of clearing the code always reminds me of this...makes no sense!
http://www.youtube.com/watch?v=ZODzdqVptUs
2009 LS9
1990 LT-5/sold/Bought my Baby back
1994 Lingenfelter LT-5/sold
1973 LS4/sold
WydGlydJim is offline   Reply With Quote
