Old 10-22-2013   #1
Don in VT
Default Rear axle nut torque spec
Hi
Is there a new torque spec for the rear axle nut or is it still 168 ft/.lbs?
Thanks
Don
Don in VT is offline   Reply With Quote
Old 10-22-2013   #2
gbrtng
gbrtng's Avatar
Default Re: Rear axle nut torque spec
Yup - bumped to 200 #-ft many years ago ... at least 10, maybe more.
Old 10-23-2013   #3
batchman
Bumped by whom?
I'm in there often enough I hesitate to overstress things. On the other hand if that will help keep them from relaxing or otherwise self destructing I'm all ears...
Thanks,
- Jeff
Old 10-24-2013   #4
My understanding is the factory revised the torque spec. My last rear bearings were torqued to 170 and left side developed the dreaded clanking. Been using 190-200 since then.
Old 10-27-2013   #5
lbszr
lbszr's Avatar
A few years ago the National Federal Mogual bearings came with installation instructions for 190lb. So far they have lasted a long time, but they will still loosen when tracking the car. I've had to retorque them probably 10 times.
Old 10-27-2013   #6
Don in VT
Hi Everyone,
Thanks for the new torque setting of 200 ft/lbs. Job is done and all is great. The ZR is down for the winter. It will be probably be for sale in the spring for $ 13,000.00. Sooner if you have a car carrier and live in the NE.
Cheers,
Don
