Old 10-15-2013   #1
bamawrx
Default question
Can anyone post a chart or tell me which cylinders share coil packs? For a 1990 in case that matters. I also need some recommendations for "must have" technical manuals. I also need to know the layout of the packs under the plenum identified by which cylinders they power. I tried to search the forum but it wouldn't work from my phone for some reason. Thanks for any assistance.
bamawrx is offline   Reply With Quote
Old 10-15-2013   #2
Default Re: question
Photo Provided by ZR1Vette (Coil Numbers Shown)
Service Manual Supplement
Old 10-15-2013   #3
bamawrx
#6 wire is top right then. I'm going to see if I can trace its pair.
Old 10-15-2013   #4
bamawrx
#6 wire is top left then. I'm going to see if I can trace its pair.
Old 10-15-2013   #5
The only one left (I mean the only one you cannot see)....that would be bottom left in photo
Old 10-15-2013   #6
bamawrx
Ok so #6 is paired with #3. I just traced the wire. That is big help. I'm going to check continuity.
Old 10-15-2013   #7
Looks to me like #6 is paired with #1
drivers side bank from front to rear:
1 3 5 7
passenger side bank from front to rear:
2 4 6 8
Firing order is 1-8-4-3-6-5-7-2
Old 10-15-2013   #8
bamawrx
Very odd. I just traced my #6 wire and its in the #2 position on your chart.
Old 10-15-2013   #9
let me check...This is identical.....I am now confused
Left side of photo is front of engine.
I assume your #6 wire goes to the Passenger side third cylinder from front?
When you say #2 position you are referring to the coil top right in photo (the pin extreme right) in photo?
Or are you talking Coil top left and pin top row in center of photo?
Old 10-15-2013   #10
bamawrx
From your photo my car has #6 cylinder wire attached to your #2 label.
