Old 10-02-2013   #21
Blue Flame Restorations
Default Re: Cam grinding
You can get any # you want on the dyno if you diddle with the system....thats why its hard to compare on dyno to the next
You might have more Brett....
Yeah, Pete's told me all about the dyno tricks that people play. I'll never dyno my motor. No point for me. I just like the way it runs. After driving Kevin's stroker, I want one of my own!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-02-2013   #22
Originally Posted by efnfast View Post
Sooo David, you're around 522 hp. 510 by Marc's numbers, that means 12 hp by cams???
No... At the time I did the dyno, I didn't have some of the items marc uses to get 510hp. (Lightweight flywheel and 63mm throttle boy)
My rwhp should be higher than 444 with those two items added. I don't want to give an estimated dyno # because I don't want to guess wrong
Intake cams add 25 to 30hp and exhaust cams add 8 to 10
Old 10-02-2013   #23
This is more or less typical of LT5s with stock bottom, cams, & TB. The power adders (call this a "base case") is full porting, relieving, headers, X pipe, 3" free flowing exhaust, and Fidanza FW. Numbers can and do vary, but due to the ambiguity associated with different dynos.
Now...Add cams = +25 ±, 63mm TB = 5-8 more, electric water pump = 8-12±. So, in this 508 "base" example, it would put it around 549 chp, or somewhere in the range of 466 rwhp, ±, depending on the dyno ambiguities and phasing differences. (Pete said he was getting 474 rwhp before his last cam change, FWIW.)
Hope this gives you an idea. Aslo, Marc has all this breakout and more on his website.
One more question comes up often, and that is the loss of low end torque that results from porting the LT5. This graph represents the rear wheel torque results I experienced "before and after". And, I'm not alone! Contrary to most of the car rag articles from "experts", I didn't lose, but in fact GAINED low and mid-range torque! You can ask Dominic or Pete, or Marc, or any of the FBI gang and they'll tell you the same thing. As long as you don't go "nuts" with the cams, it is very possible to have some respectable increase in low/mid range torque and wheel power and not loose tractability at all!
And, this is what makes the LT5 unique, and why it surprises so many people - especially those totally immersed in the characteristics of pushrod platforms.
Old 10-02-2013   #24
tpepmeie
I'd build another 427 for ya And I'm less than an hour away from you!
Todd
Old 10-02-2013   #25
Todd
Thanks for the offer, Todd. You motor sounds sick!!! (that's a good thing!!!! LOL)
Pete has dibs on the next one. Hope to do a 427 too.
Old 10-02-2013   #26
Originally Posted by Bob Eyres View Post
So, are you saying that with the cams the 91' is quicker, but less tractable and less easy to drive than the 95'?
I wonder if the combination of my light flywheel and the cams will make it a strong runner, but take a whole lot of smoothness out.
Bob,
You can come and drive my car , then tell me if smoothness is lost. If anything I think its very smooth particularly at cruise. With 350rwtq or more available anywhere from 3-6000 rpm, just keep it in 5th or 6th.
Old 10-08-2013   #27
Bob Eyres
After seeing those torque specs I don't doubt it. Gee, this engine is phenomenal.
