View Poll Results: Will you participate in the buy if there are enough sold
Yes 3 16.67%
No 10 55.56%
Possible 5 27.78%
Multiple Choice Poll. Voters: 18. You may not vote on this poll
Old 08-30-2013   #11
cvette98pacecar
Default Re: carbon Fiber Roof Panel
Apples to Oranges. Im not putting orange writing on the roof either lol. I might be a player if painted. I dont think it would look great with the white
Yeah you might be right. The Carbon top does not look that good.
Old 08-30-2013   #12
cvette98pacecar
If you want the panel painted I would suggest taking your car to a shop that can image the color to get a perfect match. If Dave paints the panel chances are the color wont match.
Old 08-31-2013   #13
rkreigh
any idea on how much the top will weigh??
costs about the same as a CF hood.
sure would look cool, and it's not a bad price either.
like to see them do this, but unfortunately "I'm out" for now as I just dropped big $$ at carlisle
Old 08-31-2013   #14
ZR1North
Originally Posted by ZR1North View Post
I am in - voted yes already. Light-weight, painted carbon fiber is just too good to pass up.
I should have been clearer. By painted, I didn't mean as in color match to the car. I meant as in whatever protective costing they put on the ZR1 carbon fiber exposed parts.
I am told a gallon of the clear coating (used on CF) is 60K, so unless the roof producer was using the coating regularly, adding the coating would probably make the top unfeasible. I am not sure exposed CF on the exterior would stand up well, and it certainly would not look as good as the unpainted (but coated) parts do on the ZR1 and other high-end vehicles.
ZR1North is offline   Reply With Quote
Old 09-01-2013   #15
Bob Eyres
Has there been an estimate of the weight differential between this and the stock part? Maybe I'm wrong, but I can't imagine more than a one or two pound difference. Is that cost effective?
Consider that, (unless you are using a damaged donor panel), you'd be spending $6-7 hundred for a donor panel, then paint. You're pushing $3K before it's done.
Old 09-01-2013   #16
if it's the same weight as the one that one of the major parts houses had at carlise 3 years ago it's substantial weight savings.
Old 09-02-2013   #17
Bob Eyres
But if reduced weight is ostensibly the reason for the new part. Why does no one seem to have an accurate number?
Is the tinted plastic panel, which I don't have, the lightest available panel available now? If so, then it would seem as if the difference in weight between the CF piece and the tinted plastic piece would be your CF weight advantage. The frame being the same, how could that be more than a couple of pounds.
Old 09-02-2013   #18
Cal55
I have both tops right now, so I don't need a third. It's a good idea but not worth the price to me, it might look okay just cleared. I can't see it being much lighter than the acrylic top either.
Cal55 is offline   Reply With Quote
Old 09-03-2013   #19
cvette98pacecar
I will call Davey tomorrow and find the weight difference with the C6 tops.
Old 09-09-2013   #20
HADI-ZR1
I will do it for 800 dollar if I got 10 buyers
let me know!
HADI-ZR1 is offline   Reply With Quote
