#21 |
NGK Irridium here too. They work great but, I'm running the TR7IX per Marc Haibeck. I assume that the only difference is the heat range.
#22 | |
Both are two ranges colder than the plugs NGK recommends for our applications. Did you simply overtighten the plugs to taper the seat on the head? I was leary of doing that and went with flat-seated replacements. |
#23 |
I ended up going with the over-torque method. So far so good it's just that the car hesitates a little when cold. After it runs for five minutes all is well.
#24 | |
![]() Join Date: Dec 2003
#25 |
has anyone tried the #5 acdelco?
#26 | |
As to plugs I have NGK's in now and have had the OEM's without noticing a difference. Mobil 1 filter and oil every 3k. ![]() ![]() |
#27 |
![]() Join Date: Aug 2005
just make sure the anti-seize does not go in the combustion chamber...leave a couple of threads clean,because anti-seize WILL cause pre-ignition..
![]() bj |
#28 | |
