![]() Join Date: Nov 2007
Hey, y'all!
I'm in the market for a new radiator (to replace the broken one on my Z). Suggestions/prices for a replacement radiator??? Frankly, the stock one with Marc's fan control program was more than sufficient for even some spirited hwy driving, so I don't think I need to go bigger. Thanks in advance!! P. |
#2 | |
I would just go with a Ron Davis Aluminum radiator and be done with it ![]() 1. Ron Davis Radiator w/o transmission cooling a. 1989-1996 C4 Type V8 All Part No. 1-16CV8996 b. Rated 800 Hp c. Manual transmission ![]() d. For the Ron Davis radiator the fan shroud inside baffles have to be cut back 5/8 inch so there is not contact with the fins of the radiator. Use a small cut off grinder for that task. e. I cut the tab on the passenger side of the fiberglass radiator housing (the single tab with larger bolt hole that interferes the most with the oil cooler hoses). The fiberglass radiator housing then slipped on easily without further modifications. LT5 Radiator and Initial Coolant Fill Tricks Last edited by Dynomite; 08-03-2013 at 10:49 PM. |
if you use a stock replacement you'll end up with one for an auto car I think. I'd rather go aftermarket and then be able to pump fluid into the rad at high rpm then not
![]() Join Date: Dec 2003
Paul i have a stocker for you come pick it up.
Just wash it/clean it and your all good. Pete
#5 | |
![]() ![]() Join Date: Feb 2010
When I rebuilt EX5023 I just bought a six speed radiator from the local parts store. ZR-1 application.
Pete's Dman!
I'd agree w Cliff. Just driving the ZR around a few weeks ago w the A/C on(picked up the wife from work) H2O temps went to 230 until I could get on the road. But stop and go is an issue with temps at 90+ and A/C.
Ron Davis is high end
I went with Fluidyne years ago |
#10 |
I agree. Went with the fluidyne years ago and it has handled the Florida weather for thousands of miles without incident.
Gary 90-1572 ![]() |
