![]() Join Date: Apr 2013
What do your cars run for oil pressure when hot? Out driving today and at 2k rpms or so (cruising) the dash guage reads about 40. At idle it drops to near 0 and needle fluctuates a bit. No knocking or anything from engine. Runs fine. Oil was just changed less the 200 miles ago. Mobil 1 10 -30. Thoughts?
A bit low especially at idle.......I run from 60 to 50...maybe 45 at slow idle. Exchange the Gage Oil Pressure Sensor (the one that sits vertical in front and on top of Oil Filter Housing) to see if any difference.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-12-2013 at 04:14 PM. |
Is that sensor something u can get anywhere or is it one of those hard to find deals?
Think I found em on Amazon D1808a... Just went out and checked oil after car sat for couple hours. It looks fine. Started it back up, oil pressure at idle was about 35-40 by the gauge, 60 or so revved up. Idle pressure was about 20-25 after engine got to 220 degrees or so - needle fluctuated a bit. When the A/C compressor kicks on it drops the idle way down and I hear a rattle from rear of engine. Other then that it doesn't knock. This car has 18k miles on it... Gonna order the sensor but any other ideas are welcome.... Last edited by Racinfan83; 07-12-2013 at 04:13 PM. |
![]() Join Date: Dec 2003
The rattle from the rear of the engine is probably the dual mass flywheel if the idle is lower than 700.
Engine rpm is supposed to go to high idle when the AC is on. I've never been a fan of electronic senders for critical engine conditions, so I installed a pillar mount, direct reading oil pressure gauge. Short of that, I would recommend that you at least temporarily install a gauge in the 1/8"npt hole where the oil pressure sender goes, just to confirm a "real" reading. Then you can correlate that to the analog display on the dash & have a better idea what is real. FYI, there is a separate, low oil pressure "switch" that will illuminate for low oil pressure. Given that you are not seeing that, and the analog needle is fluctuating, I agree with Dynomite that the sender is probable faulty & should be replaced.
Thanks! I took a video of it - trying to get it uploaded so u guys car hear it...
![]() Join Date: Nov 2011
Hey, do you think Jerry's gaskets has those?
Here is a video I just took of starting it and running with the A/C on:
http://www.youtube.com/watch?v=9WrCX...ature=youtu.be |
#10 | ||
![]() Join Date: Jan 2012
Every once in a while my gauge drops to 0. The first time I noticed this, I freaked out. I threw it into neutral and was about to shut it down when the needle shot back up. Hmm ...
BTW, it's hard to tell what the analog gauge is reading as the gauges are "non-linear." Quote:
![]() Jerry made a good point about the "oil light." Since I don't see that, I assume I really have oil pressure even when the analog gauge shows 0 for a few seconds. |
