Old 06-18-2013   #1
Locobob
Default Ported Intake for Sale
Ported 91 (will fit 90-92) Plenum and Injector Housings
Bolt on 20+ rear wheel horsepower!
$1500 outright or $900 + exchange for your unported parts
Robert
Old 06-18-2013   #2
Default Re: Ported Intake for Sale
Bob what level of port is this ?
Old 06-18-2013   #3
Locobob
This is designed to go on a stock or mildly modded 350 cid. Pretty much anything else is going to have ported heads and you'd want to match the intake to the head porting. It's 36+mm throughout except for the primary runners which funnel down from 36mm about half way down the injector housings to 34mm where it meets the head - stock primary head ports are 32mm at the gasket surface.
Robert
Old 06-18-2013   #4
Jagdpanzer
Jagdpanzer's Avatar
Robert,
Excellent work!
Tell us how you managed to finish the runners inside the plenum?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-18-2013   #5
Locobob
Robert,
Excellent work!
Trade secret
Well okay.... this pic should explain it... and yes it is a very time consuming pain in the *** to do.
Robert
Old 06-19-2013   #6
batchman
Nice work. How about a dumb Q from a guy who has to sweat class rules.
If primary head port is 32mm, what is secondary head port size (stock)?
I ask because I'm limited with respect to work in the head, can only go in one inch. That would seem to be enough to take up the 32 to 34mm...
Hmmm... Mo Powah - tasty!
- Jeff
Old 06-20-2013   #7
Locobob
- Jeff
The secondary head ports at the gasket surface are a hair over 36mm stock - this is where the secondary butterfly valves are and they take up some space so a "bulge" here was part of the design to compensate.
Robert
Old 06-20-2013   #8
Thumbs up Re: Ported Intake for Sale
Me likey
Old 06-20-2013   #9
Locobob
Originally Posted by FU2 View Post
Me likey
Trade ya for that 440 Frank...
Robert
Old 07-06-2013   #10
Locobob
Forgot to mention that I went ahead and opened up the plenum throttle bores to 2.5in so if you have or may get a 63mm throttle body someday you'll be good to go with this.
Robert
