#11 |
drain it with the car level for 30 min...it will hold 8.5-9 quarts. The whole system is like 12 quarts. It helps if you poke a hole in the top of the oil filter to help it drain out and not make a mess.
#12 | |
![]() Join Date: Jul 2010
peace Hog |
#13 | |
![]() Join Date: Jan 2009
I'd say it's garbage ![]() There is no need to get to every last drop. If that were the case you'd need to dismantle the engine and wipe out every crevice. I don't wait 24hrs for the oil to drain and I don't pull up the carpet to get to the dirt underneath. I'd stick with a good oil. Not something sold out of someone's garage. AND I'd run it good and hard and hot before changing so as to get the oil out in the radiator stack to circulate. Then since you're not sure when it was last changed I'd change it again in 500 mi to better get more of the 4qts that is not readily accessible (~12qts - 8qts = 4qts) I use Pennzoil Ultra Synthetic.
#14 |
I couldn't agree more.Warm up the car,get it up in the air and drain the oil,20 minutes tops.Now,if your doing the first oil change I can see letting it drain as much as possible,dont know what kind of oil was use but for a basic oil change,its no different than any other oil change as far as Im concerned.
#15 | |
![]() Join Date: Apr 2013
My Civic dumps oil all over when I unscrew the filter. Never even thought about putting a hole in it to drain it "nicely".... Man, I feel like an idiot now... ![]() |
#16 |
![]() Join Date: Jun 2005
The part about waiting overnight is not for the oil to drain out of the pan, it's for the oil filter to drain so, when you change it, oil doesn't leak out the base and down onto the right front of the engine.
What I do is, in the evening after work, I drive the car up on 2x4s. Then I get the floor jack under it and put the car on stands with the right side a "notch" higher than the left. I pull the drain plug and let it drain for a while. As others have said, you can't get all the oil out, anyway, so overnight is not going to make much difference. I put the plug back in, set the car back on the shop floor then let it sit over night. In the morning, I come out and change the filter. No muss, no fuss. Been doing my '95 that way since I bought it in '95.
