03-25-2007 | #1 |
SUPERCHARGING AND TWIN TURBO THE LT-5
WE ALWAYS GET THIS SAME ? FROM THOSE WHO WANT MORE SO HERE IS A COMPILATION OF THE VARIOUS COMMENTS AND ?'S ON IT!
http://zr1netregistry.com/forum/showthread.php?t=3016 BETTER OFF TO SC (CENTRIF TYPE NO HOOD NEEDED AND COMPRESSION IS NOT A PROBLEM IF YOU KEEP THE BOOST LOW @ <5 PSI) AN LS1 C5 VETTE IS WHAT MOST END UP DOING. HERE IS AN EXAMPLE OF ONE>> http://zr1netregistry.com/forum/showthread.php?t=3031 NOW U CAN TURBO AN LT-5 BUT AGAIN BIG $$$ HERE IS A DISCUSSION OF IT>> http://zr1netregistry.com/forum/show...ght=TWIN+TURBO http://www.speedshopthagard.com/proj...ZR1/index.html AND A FEW MORE>>> http://www.geocities.com/MotorCity/Street/8943/ http://www.corvettemagazine.com/2001...king/king1.asp http://zr1netregistry.com/forum/show...ght=TWIN+TURBO http://www.turbochargedpower.com/ THIS SHOULD FILL YOU NEED TO KNOW!!! ENJOY AND WHAT DO YA KNOW ---MY 1,500TH POST HOW APPROPRIATE!!!
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln Last edited by WB9MCW; 03-25-2007 at 04:16 PM. |
03-30-2007 | #2 | ||
Re: SUPERCHARGING AND TWIN TURBO THE LT-5
There are no free rides, but some are cheaper than others. Supecharging is a parisitic drag on crank horsepower. The power to turn the blower/supercharger/puffer comes directly from the crank. For descriptive and ease of demo purposes only, assume an engine has 400 crank Hp, in normally aspirated configuration. Install a supercharger which requires 50Hp to operate @ 6 psi boost, yielding a Hp increase of 50%, expressed as follows;(400Hp-50Hp)*150% = 525Hp A turbo derives its power from exhaust gasses. Turbos do not create drag but do reduce engine horsepower in a much reduced way by inducing back pressure on the exhaust, thereby lessening cylinder evacuation efficiency. Once again, numbers are for demo purposes only, but are somewhat relative to supercharging. Install a turbocharger which reduces engine efficiency by 5% (20Hp), operating @ 6 psi boost, yielding a Hp increase of 50% (boost is boost) expressed as follows; (400Hp-20Hp)*150% = 570Hp. If turbos are better, as in more efficient, why do more folks go with superchargers. Answer, until now, is less cost & simpler installation. UNTIL NOW: Ron Hanselman & I have formed a new company called Raptor, LLC for the express purpose of developing rear-mounted turbo systems for the C-4 Corvettes, LT5, LT4, LT-1 & L98. Only the Lt5 will be a twin turbo configuration. The others will be single turbo design. Rear mount systems are much less expensive and much less difficult to install. Our system will be sold in kit form, with everything you need to install it, much like a cat-back exhaust system. There will be optional components. We have a 90 ZR-1 and a 95 LT-1 nearing completion now and our plans are to have them both at Bowling Green for the Gathering. You may have seen STS Turbos (Squires Turbo Systems) shows on the SPEED channel about the C5 systems. Raptor has an exclusive agreement with them and will be featured on STS's website once our systems are ready for sale. Quote:
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 03-30-2007 at 09:02 PM. |
03-30-2007 | #3 |
i'm confused the link..takes us to a car that is listed as blown?
or were you referring to the model?? i'm super excited about twin turbo kit. =D> |
03-30-2007 | #4 |
My Bad!! I left the likns in that Bryan had in his original post, separated the quotes without adding new "quote" syntax. Fixed now....sorry for the confusion.
03-31-2007 | #5 |
Thanks for the update Jerry, I think many of us have been watching for you and Ron's progress on this project...excellent stuff!
SteveB '94 ABZ Lucky #13-SOLD |
04-01-2007 | #6 |
Great news indeed Jerry. Glad we brought the subject up and you made the announcement and the comparison of SC vs Turbo- in the LT-5 case TT.
We look fwd to the future reports. Will the TT work for stock motors at low psi? How much more HP when PnP intake- now add PnP Heads? how abt a stroker like your 415 or 385 with P an P and exhaust mod's. What do you see as the line up hp from a TT from stock to wild and what boost at what mod levels do you envision with your new rear TT design? It is ironic you bring all this up when I made a comment about your own ZR-1 LPE and a second TT ZR-1 (Paul D's TT) article and Ron piped in abt the correct scoop on your SGC 415 etc--in a way it is like I knew you were planning a TT ---or thinking of it presuming that you do your 415 SGC engine up with a TT kit? -- to wierd-- http://www.zr1netregistry.com/forum/...0029#post10029 If u need a free website (for your new TT venture) MS live essentials office websites are free! I have made two for my biz this last year. Easy to set up and operate even the online store I believe- all free. Check it out-- http://office.microsoft.com/en-us/of...465131033.aspx my sites: www.apogeeindustriesinc.com and www.wadsworthsales.com
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln Last edited by WB9MCW; 04-01-2007 at 05:11 AM. |
04-01-2007 | #7 | ||
Thanks for your interest!!
04-01-2007 | #8 |
Well Ron might be able to post results of various combo's on the forum or on the main site in that existing chart of mod's and times--- all though that is rather old data charts etc. Maybe a new updated on is in order.
Will be exciting to see the results of this I know many who have talked of desire for this type of TT kit. Bravo
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln |
04-01-2007 | #9 | |
04-01-2007 | #10 |
No problem Jerry---We like to point out the "special" ZR-1 owners that promote the KOTH and then some here on the forum!!!
