Old 05-10-2013   #1
Default Experimental Bling
Billet Aluminum Ultra Light Belt Tensioner Pulley
Just experimenting with a Billet Aluminum High Speed bearing Belt Tensioner Pulley. You get a nice new Pulley Bearing and Pulley diameter is only 3/16 inch larger than stock otherwise Pulley dimensions are identical to stock. The larger diameter will move the belt tensioner counterclockwise at the bearing center only 3/32 inch more which is insignificant
To be installed and tested within a few days after I get Plenum back on my 90' (with some modifications to IH and Plenum of course )
Belt Tensioner Billet Aluminum Ultra Light Pulley
See item #9c of Bling (Carter and Others)
Old 05-10-2013   #2
vilant
Default Re: Experimental Bling
Just experimenting with a Billet Aluminum High Speed bearing Belt Tensioner Pulley. You get a nice new bearing and Pulley diameter is only 3/16 inch larger than stock otherwise Pulley dimensions are identical to stock. The larger diameter will move the belt tensioner counterclockwise at the bearing center only 3/32 inch more which is insignificant
Looks very nice, you'll have to post pics of it installed. Did you port them or something else?
Joe
1990 Bright Red ZR-1 #2599
Old 05-10-2013   #3
Corbusa
DYN., it looks sweet but you guys bling pulleys and alternators etc etc etc etc etc is stressing me out . I cant work enough hours.. geezzzzz I hope i hit the lottey soon..
pictures please.
Old 05-10-2013   #4
pictures please.
50 bucks for pulley and nice new pulley bearing
I just do not like that plastic stuff
Old 05-11-2013   #5
Corbusa
Let me know when and where . You da man .
Old 05-13-2013   #6
dzim
I am interested also. Please keep me informed.
Thanks,
Dale Zimmerman
dzim is offline   Reply With Quote
Old 05-16-2013   #7
Thanks,
Dale Zimmerman
I have to instsall a new water pump and some other stuff so will be a week or so before I fire it up with the new Belt Tensioner Pulley. I will take a picture and tell you how it works out
In the mean time
Brass Colored Alternator Pulley
Ebay Brass Colored Alternator Pulley
Delco CS130D Alternators 6 Groove Pulley 10476225
This pulley is identical in Outside diameter and Shaft Diameter of original Alternator Pulley. I very thin washer (3/64 inch thick) was used between the pulley and the cooling fins of alternator for exact Pulley spacing.
Alternator, Spacer, Pulley, Washer, Nut,
5/16 inch Allen, 15/16 inch Box Wrench.......................Modifications to 15/16 inch Box Wrench
Old 05-24-2013   #8
Getting close to installing the belt
Old 05-24-2013   #9
Corbusa
Thanks DYN keep us posted on the pulley's where and when .
Old 05-29-2013   #10
All Up and RUNNING
Ebay Billet Aluminum Belt Tensioner Pulley
All Pulleys are super quiet and run sooooooo smooth at all RPMs.
Summary of 90' Reconditioning/Modifications
You will notice this photo taken with engine running is not blury at all indicating absolutely NO VIBRATION
Of either the Alternator Pulley or Belt Tensioner Pulley.
