Okay I have finally gotten back in the states and have some time. I am going to pull my Plenum on my 91 Z this weekend so I can rebuild my starter. Is there anything else I need to attend to While I'm in there. All advice and links are welcome about anything My car has 88,000 miles on it.
Dave Last edited by ZBrink; 01-25-2025 at 09:24 PM. Reason: edited for clarity |
![]() Join Date: Dec 2003
Look for brittle vacuum hoses, lose connections, oil and dirt in the valley. Check the drain hole is clear.
ZR-1 Mom Founder ZR-1 Net Registry Founder ZR-1 Net NCM Lifetime Member |
#3 | |
![]() Compressed Air works great from below on the valley drain tube just to the rear of the oil pan on passenger side. Now........get ready for some fun ![]() Oh......drain some coolant first so when you remove the plenum the Throttle Body (TB) coolant is not getting into the Injector Housing. Or....here we go..... ![]() Block the TB coolant when you are there ![]() LT5 Eliminated Systems
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-25-2013 at 11:53 PM. |
![]() Join Date: Jan 2012
check the crankcase breather hoses and especially the clamps mine were loose and letting oil leak out of them, also the vent cover bolts,gasket,etc,etc.
![]() Join Date: Mar 2007
remove that pesky additional aluminum from the runners if you have not already
How much coolant should I drain for a upper plenum pull??
Dave |
I removed one and a eighth gallons by tapping into the line that goes to the radiator from the coolant resevior like is depicted below is this sufficient for a upper plenum pull?
Dave |
#8 | |
![]() PLENUM Plenum pull TIPS Plenum Removal Simplified TIPS LT5 IH, Fuel Rails, Plenum Install Tricks Plenum pull questons Plenum pull tools and parts Plenum pull parts Under the plenum Plenum bolts install Porting Plenum & Cam cover restored pictures Plenum gasket drawing Ebay ZR1 LT5 Plenum
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-27-2013 at 12:52 AM. |
it looks like my a/c compressor is leaking and its a little oily on the vent box and looks like some one did a little mild porting in the past, what do you all think any observations or suggestions??
#10 |
If you are referring to the cresent shaped cuts in the IH to head surface that is factory matching, not porting done later.
PORT IT!!!
