Old 02-04-2013   #1
Corbusa
Default The Prom
Does any one make a Prom/ after market ? I should just explain what I'm wanting to do.. I'd like an extra prom for a spare .. Keep my factory one left alone and buy a spare to have calibrated for my upgrades. best way or what to buy?
Old 02-04-2013   #2
Default Re: The Prom
there are several people that are excellent at chipping..Marc Haibeck will do you right.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 02-04-2013   #3
WVZR-1
You need go no further than Marc. Make note of anything you've modified or intend to do soon and he'll accommodate you no doubt. Do you know if you've got the "most current" updated GM PROM? Through the window on the blue cover there will be a code printed on a silver label. The most current is AYBK and part # 16163905. I might have an NOS of that. I assumed the car we're talking about is a '90MY.
Old 02-04-2013   #4
Corbusa
I'll call Marc... also I see that 1990-1995 ecm's are the same ( this is what I read ) .That does mean 1990-1995 ZR1's not just corvettes Correct? a spare ecm would be nice also...
Old 02-04-2013   #5
Really no reason to do that. You can always re-burn the chip w the original calibration as long as you have saved it on file somewhere. Once you do the mods, the stock chip won't be optimum anyway.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-04-2013   #6
Corbusa
True XFire.... Can teh proms go bad? should I have2 and keep one in the glove box?
Old 02-04-2013   #7
Anything can go bad but highly unlikely. At worse, you can use a daughterboard like Moates to sub for the OEM chip with a re-burn of the calibration. As for the calibration itself, that's already available from many of us anyway. A spare ECM is always a nice thing to have.
Old 02-04-2013   #8
RHanselman
RHanselman's Avatar
Corbusa,
You could just pull out the entire ECM and install the new Plug and Play unit that will be available very soon. The new units are USB programmable and will host the newest technologies. No chip required...
You could put your's stock unit on the shelf until you want it again.
Cheers,
RH
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 02-05-2013   #9
Corbusa
Keep me informed!!!!
Old 02-05-2013   #10
Concur
I actually have two chips for each Corvette (87 Octane and 91 Octane) all modified by Marc Haibeck
