02-04-2013 | #1 |
For tuners, a Holy Grail of Injector voltage Offset
Gentlemen,
The Holy Grail of Injector Voltage Offset: http://injector-rehab.com/shop/lag.html If you look through this you can see how different injectors act under varying voltages. You can compare the Bosch v Accel and RCs for example. With longer opening times you get less fuel for the same calc'd pulse width. That's why it's important to get this offset right since it makes tuning fuel more accurate. If you have ever felt that your car has idled roughly after a long hot run, this is one of the reasons why. Once you modify this parameter, you'll need to re-check your fuel tables by datalogging.
02-04-2013 | #2 |
Re: For tuners, a Holy Grail of Injector voltage Offset
I like the listing to use for comparison purposes, but they neglected to show the unit of time.
02-04-2013 | #3 | |
Interesting the variance in resistance from unit to unit even within one vendor per part number.
Scott Vett owner since 1979._It's about the car and the people Last edited by scottfab; 02-04-2013 at 03:09 PM. |
02-04-2013 | #4 | |
Yes, its msec. And the variance is the point of posting this. An injector isn't just an injector. Swapping different brands, although same fuel flow rating, has consequences in the tune. This is especially true at idle and short pulsewidth situations where the opening time is a proportionately larger part of the total calc'd pulsewidth. Now some on this board might say, "yeah but.." when you tune to 14.7:1 or to a 128 BLM, doesn't the ECM overcome this. Without the correct injector offset, you'll undershoot or overshoot the actual calc'd pulsewidth the ECM is looking for. In some cases, you may "run out of injector" or have too high a duty cycle. By using the correct offset, you may find that you can lower the overall VE% and have a smoother VE map which means the motor operates more smoothly and predictably in varying conditions.
02-04-2013 | #5 | |
I have the Lucas ones- I can't recall if they are 19 or 21 lb rated though. |
02-04-2013 | #6 | |
RC injectors.
02-04-2013 | #7 |
This was the example I was comparing to:
__________cc. lbs/hr. ohm -> 10v 11v 12v 13v 14v 15v RC Engineering: 240 23 16--> 1.31 1.10 0.97 0.77 0.62 0.46 |
02-04-2013 | #8 |
Yes that's right. And at 14v the stock Inj. Offset is .3msec compared to .62. You would note a difference if you made that change in the cal.
02-27-2013 | #9 |
For anyone wondering what this thread was all about, I just stumbled upon this, which explains it very nicely.
http://www.injectordynamics.com/GMDATA.html Jep |
02-27-2013 | #10 |
Being that this is a tuning thread, let me hijack it a bit.
What do you guys do for engines forced to run on E10? Do you work with E10's different stoich or do you just tune for a certain lambda value from your wideband?
