Met an interesting guy whom owns an 88' prototype among other things, filled me in on a lot of the little quirks of the zr-1. Apparently, the grease used on the ignition module on the underside of the plenum is there to cool the module. Anyone know what type of white grease this is? Can I just get it at an autoparts store? Thanks.
#2 | |
![]() Join Date: Oct 2004
![]() Join Date: Nov 2007
Caution:
P. |
#4 | |
#5 | |
![]() Join Date: May 2005
Tyler |
![]() Join Date: Jan 2009
Thermal grease does not have to be white.
It also comes in clear. White is easier to see when applying. I use a military grade thermal grease which is clear. I've had this tube for almost 40yrs. Here is one inexpensive single use non military source: http://www.thenerds.net/ANTEC.Therma...FSFyQgodZ3kAqA
No air bubbles either.
I saw a pc shop tech put the paste on the back of the heat sink, IN A LITTLE RING ![]() I've read twice that copper anti-seize has better heat conductivity that some heat sink pastes, and I don't know how to test for heat conduction... |
![]() Join Date: Nov 2006
I use Dow Corning 340. I took it apart after 3 years of use and it was still as greasy as when applied, no drying, or cracking. It's white.
