Go Back   ZR-1 Net Registry Forums > Off Topic > OFF TOPIC
Old 01-13-2013   #11
Fully Vetted
Fully Vetted's Avatar
Default Re: Countdown to C7
Separated at birth
Really it's just the front that is similar. Vette is much more angular. I like both till we get to the backside.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 01-14-2013   #12
Fully Vetted
Body Double:
Body double:
Just sayin'...
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 01-14-2013   #13
USAFPILOT
USAFPILOT's Avatar
I like it...cant wait for higher performance versions to surface. So far the Viper has my attention.
Old 01-14-2013   #14
Jagdpanzer
Jagdpanzer's Avatar
2000 psi on the fuel rail.
wow.
Better not get a leak.
Scott,
2000 psi is not all that high. Common rail Diesel engines today run with fuel rail pressures of 25,000 psi.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-14-2013   #15
scottfab
scottfab's Avatar
Scott,
Yah, I'm sure there are higher pressures in air craft carriers and locomotive diesels too. Come to think of it there are hydrolic systems that run 30,000psi that carried that space shuttle. But then they are totally different animals too.
I don't know of a corvette or other gasoline engine with 2000 psi.
Scott
Old 01-14-2013   #16
scottfab
scottfab's Avatar
Definitely has a few "sharp" angles like the Aztec.
I suppose I'll get use to it like a bad fitting tooth crown.
Originally Posted by Fully Vetted View Post
Separated at birth
Scott
Old 01-14-2013   #17
DaveK
Monstrous carbuncle... I don't have a problem with different, just fugly...
Dave
1991 #1516 Black/Black
davidmkelly.com
Old 01-14-2013   #18
I'm with David (fully vetted), I hate the new c7 azz and love the accurate pictures!!!!!
Thanks, you made my morning!
Old 01-14-2013   #19
Just sayin'...
Now THAT"S a nice azz !!!
Old 01-14-2013   #20
BigJohn
BigJohn's Avatar
Is it not to better vaporize the fuel; like in the Chevrolet Traverse???
