Old 10-02-2012   #61
Paul in SC
Paul in SC's Avatar
Default Re: Ready for the oil catch can...
Thanks for all the replies and pix.
It is something I will put on my to do list.
Paul
1993 ZR-1 - "The Green Thing", LPE/LSV 385; 2021 HTC, Red Mist Metallic, Cool gray interior, stainless dual stripes; ZR-1 Net Registry #1376
Paul in SC is offline   Reply With Quote
Old 01-11-2013   #62
Blownrunner
I used a water separator from home depot, 90 degree brass fittings, and fabbed an aluminum bracket. Installed on master cylinder. It is quite small and fits nicely
Blownrunner is offline   Reply With Quote
Old 01-11-2013   #63
Aurora40
Aurora40's Avatar
Originally Posted by vilant View Post
Got a noob question. I have a 90', and when I took the air intake off, I noticed a little bit of oil in the plenum. Is that normal? I know the reason you add an oil catch can is to stop that. But, I don't see a "factory" oil catch can. Why didn't GM put one in. Did they design the engine knowing it was going to suck in some oil and it would just burn off?
The oil has fuel in it, I believe one of the purposes of the PCV system is to evacuate any fuel blowby and keep it out of the oil. I suspect they can not catch it and be EPA compliant, so the fuely oil is burned through the engine.
Bob Saveland
Former owner of #2517
Old 01-12-2013   #64
Blownrunner
Hi.....and welcome
Do you have a photo of your unique Oil Catch Can set up?
If you like, you can send it to my e-mail (left click on my ID and view e-mail address) and I can post it up for you.
Yeah, give me a bit and I will snap a picture of it. I used same setup for about three years on my toyota. I drove the car for 50 miles and it has an 1/8 of oil in the bottom of it. I needed to remove and cap the drain valve on the bottom of the bowl though. I just cleaned out the plenum and didn't want the oil in there again.
