01-07-2013 | #1 |
What projects or modifications do you have planned in 2013?
Hey folks, I thought it was time to share what we all have planned for our Zs in 2013. I'm on my arse and was supposed to do some of these in 2012, but somehow other priorities too precedence and it never happened. Some of my plans are dependent on if I am moving back to Hawaii in a few months, but none the less, here are my plans:
1. Remove power antenna and install tune trapper stealth unit under rear tray; plug hole for now until I can shave hole with new paint job (on the shelf, need to find plug and paint) 2. HID headlight conversion (on the shelf) 3. Install DRM coilover suspension with new FX3 shocks and Banski complete C4 rear kits (waiting for DRM kit, Carter brackets, and Banski set-up) 4. Install C5 mirrors (on the shelf and already painted color matched) 5. Replace steering wheel with Momo competition and install NRG hub quick release/lock (on the shelf) 6. Make Christmas wreath for next year out of stock steering wheel once removed (XMas 2013) 7. Put SW headers back on and install new SW X pipe w/Dynomax Ultraflo 17220 (single 3" in/out) and Pypes Challenger tips (on the shelf) 8. Autometer dual gauge pillar mount with wide band A/F and fuel pressure gauges (have mount, need gauges) 9. Repair/replace two front speakers that are not working Not in any particular order. Happy modding in 2013! Craig
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 Last edited by HAWAIIZR-1; 01-07-2013 at 05:51 AM. |
01-07-2013 | #2 |
Re: What projects or modifications do you have planned in 2013?
I don't have an antenna on my car. I don't know how Dave pluged it, but you can't tell I ever had one.
Never had any use for it anyway! |
01-07-2013 | #3 |
I've been looking at the Tune Trapper as well. Pretty neat little piece of equipment.
01-07-2013 | #4 | |
Yeah I was looking at one too.. but I have to wonder how well it actually works..
01-07-2013 | #5 |
Replace upper A arm bushings with well greased urethane ones
that match the bottom A arm ones done a few years back. New front tires to match rear Goodrich ones. This all depends on no more things like flying metal debris hitting my other car while driving down the road AND no more leaking 85gal fish tanks in my living room. gezzzz It makes a person wonder about the number "13" as in 2013.
Scott Vett owner since 1979._It's about the car and the people Last edited by scottfab; 01-07-2013 at 12:05 PM. |
01-07-2013 | #6 |
Replace rear 335's with 345's. The 335's sure didn't last very long. Hmmmm????
01-07-2013 | #7 |
That had to be a mess.. What kind of Fish
( sorry to get off topic)
01-07-2013 | #8 | |
Opening the TB to 63mm
Re-lining the roof panel Tires. (I'm favoring the Nitto 555 and 555Rs. Thoughts?) Quote:
Suddenly the road was covered with some kind of chunky, bloody, mess that covered the entire lane for a couple hundred yards. I didn't see it until the car in front of me suddenly merged into an adjacent lane and I had nowhere to go but straight ahead. And the SMELL! OMG, I immediately started choking down vomit - the smell of rotting flesh was horrrrr-endous!! Turns out a tanker truck carrying chicken guts, etc to a rendering plant lost its load. One of the electrically operated bottom dump hopper doors opened wide, spilling the entire contents of one of the tanker cells out onto the roadway. The smell from the undercarriage remained in spite of using a double handful of quarters at a carwash. After 3 more days, I discovered some "treats" had gotten up on top of the cat heat shield and were cooking still... P.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 01-07-2013 at 10:25 AM. |
01-07-2013 | #9 |
[QUOTE=Paul Workman;159236After 3 more days, I discovered some "treats" had gotten up on top of the cat heat shield and were cooking still...
P.[/QUOTE] Paul, and they say there are no free lunches anymore!
01-07-2013 | #10 |
1. Carbon Fiber Dash Treatment APSIS Awaiting return of pieces
2. Install CF Shift Boot 3. Replace Console Sides 4. Replace A Pillar molding 5. Install new to me non cracked passenger door panel 6. Replace door weather stripping (not the upper sweeps) 7. Install ZR-1 AO diffuser plate (After Painting) 8. put on New Speed lingerie Nose Protector 9. put on new Speed lingerie mirror covers 10. Get AC serviced AGAIN Fing leak! 11. Touch up dingleberry on rear spoiler Continue to tune car with Dom Until we get it close in the Ostrich II
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-07-2013 at 10:42 AM. |
