Old 11-19-2012   #1
VetteVet
VetteVet's Avatar
Default Anyone in the Raleigh/Durham area?
I'm interested in a ZR-1 in that area and was wondering if anyone would be willing to take a look at it for me.
I'm trying to find the replacement for my '91 that was taken by Hurricane Isaac.
I haven't come to terms with my insurance company yet, but wanted to go ahead and get the search going for the replacement.
Thanks,
Jep
VetteVet is offline   Reply With Quote
Old 11-23-2012   #2
Captain A
Captain A's Avatar
Default Re: Anyone in the Raleigh/Durham area?
30 min from Raleigh, PM me and let me know what you need.
Captain A is offline   Reply With Quote
Old 11-25-2012   #3
VetteVet
VetteVet's Avatar
Thanks for the offer. I ended up backing off of that car because of paint issues (swirl marks, chips and scratches). I just got back from Florida with a super clean 1991 Steel Blue Metallic car with 62,000 miles.
Jep
Old 11-25-2012   #4
Fully Vetted
Fully Vetted's Avatar
Oooh! Steel Blue! Nice...
Pics?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 11-25-2012   #5
VetteVet
VetteVet's Avatar
Pics?
Thanks, I'm sure that your Admiral Blue/Gray is a looker!
As soon as I get the new car cleaned up, I'll post up some pics and info.
Jep
Old 11-25-2012   #6
Daniel_Mc
Daniel_Mc's Avatar
Jep
Jep,
Nice find that'll make 2 SB cars in LA we need to all get together sometime.
Daniel
[COLOR=black]Daniel McGuffee [/COLOR]
[B]1989[/B] Red Coupe #10166
[COLOR=black][B]1989 [/B]Black[/COLOR][COLOR=black] Coupe #23990[/COLOR]
[COLOR=black][B]1991[/B] ZR-1 White #1639[/COLOR]
[COLOR=red]FRANK APPROVED ZR-1[/COLOR]
[B][COLOR=red][COLOR=black]1996[/COLOR] G[/COLOR][COLOR=blue]rand[/COLOR] [COLOR=red]S[/COLOR][COLOR=blue]port[/COLOR][/B] [COLOR=black]Coupe #564[/COLOR]
"It's not about the car, it's about the people..." DJ
Don't forget to support your [URL="http://corvettemuseum.com/"]National Corvette Museum[/URL]!!!
Old 11-26-2012   #7
CJ_ZR1
Jep
Jep,
Congrats on the Steel Blue Metallic Z
Best color in my option but I could be a little bias Interior color?
As Daniel said above, we will defiantly need to get together sometime being that we are fairly close.
CJ Daniel
[B]1991[/B] ZR-1 #834 [COLOR=royalblue][B]Steel Blue Metallic/Steel Blue[/B][/COLOR]
[COLOR=red]Frank Approved ZR-1[/COLOR]
[SIZE=1]- Ported air horn, throttle body, plenum and injector housings (Tommy Morrison)[/SIZE]
[SIZE=1]- FIC SS Injectors / Nology hot wires / Screemin Deamin coils[/SIZE]
[SIZE=1]- Fluidyne aluminum radiator and 9 row aluminum oil cooler[/SIZE]
[SIZE=1]- 4.10 gears / Fidanza light weight flywheel / Hurst short throw shifter[/SIZE]
[SIZE=1]- Stainless Works long tube headers / Borla exhaust with x-pipe[/SIZE]
[SIZE=1]- DRM Coilovers / 32mm front 26mm rear sway bars[/SIZE]
[SIZE=1]- ASM bolt in 4 point roll bar[/SIZE]
[SIZE=1]- 93 ZR-1 Sawblades[/SIZE]
CJ_ZR1 is offline   Reply With Quote
Old 11-26-2012   #8
Blue Flame Restorations
Jep, congrats on the new "Z"!! At least you'll have some new bumper moldings if you need them.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 11-26-2012   #9
mike100
Interested to see it. Does it need the usual TLC, or is it it nearly perfect?
Old 11-26-2012   #10
VetteVet
VetteVet's Avatar
Daniel, CJ, Brett & Mike,
Thanks!
It is Steel Blue Metallic with matching interior. Car has had a repaint. Paint is not perfect, but not too bad either. Car is not show quality, but is very clean. Looks to have been garage kept through most if not all of it's life. Engine top end needs to be re-finished, but engine compartment and undercarriage are very clean. Mechanically and electrically, it's very sound. The only issue so far is a bad AC compressor, which was disclosed by the seller. I haven't had a chance to get any pictures yet, but here are some from the seller's ad:
Plans are to install the following, which I alraeady have:
C5 Z06 calipers and rotors
Polished GM A-molds (17x9.5 & 17x12) with Michelin Pilot Sports
4.10 rear
Swaintech coated SW headers
Corsa exhaust
ZF Doc beam plates and short throw shifter
AO Engineering air filter housing
It sure felt good to be behind the wheel of a Z again (it's been about 2 years). Permagrin is back!!
More to come!!
Jep
