08-26-2012 | #1 |
Vacuum Pump Repair
I can't resist a challenge on repairing things.
Back about 12yrs ago my secondary vacuum pump failed. I took it apart and replaced the diaphragm in it. The I used epoxy to hold the cover for the diaphragm in place and avoid leaks. Well 12yrs later it fails again. This time I fashioned a bracket that fits over the vacuum pump and holds the diaphragm in place. This way I can get back in and put a new diaphragm in without having to chip away at the glue holding the cover for the diaphragm in. Picture of damaged diaphragm http://zr1.net/forum/album.php?album...pictureid=1445 Picture of bracket around pump http://zr1.net/forum/album.php?album...pictureid=1446 Not the prettiest thing in the world but oh so functional.
08-26-2012 | #2 |
Re: Vacuum Pump Repair
In the picture of the diaphragm you can see the split in the rubber right at the point where the metal washer touches it when it's in the pump.
08-31-2012 | #3 |
Sweet thanks for the info..
09-01-2012 | #4 |
Mines in a box in the garage along with the rest of the secondary junk. I wont break if it isn't installed.
[I]4-cam[/I] [I]1991 ZR-1 Blk/Gry #31[/I] [I]SW Headers/Xpipe- Dynomax Muffs[/I] [I]Ported top end[/I] [I]Secondaries Removed[/I] Tune by Dominic |
09-01-2012 | #5 |
I'm happy for you. Thanks for sharing your insight.
09-06-2012 | #6 |
Hi Scott,
Nice pix, BTW, is that a TEK scope in the background ? Cheers, Don ( ex Tektronix engineer) |
09-06-2012 | #7 |
Don
Yes as a matter of fact it is a 2230. One of those I was responsible for. (also ex Tektronix eng)
