Old 07-21-2012   #1
cvette98pacecar
Default Electrical Short.
Is there any other fuse panel other than the panel on the right side of the dash?
I am almost positive the 93 has a short. I disconnected the negative terminal off the battery and connected a meter between the Negative wire and the negative on the battery there is 12vdc present on the meter. I pulled every fuse in the fuse panel and I still have 12vdc on the meter.
I checked to see if there was any aftermarket wiring that I could see and I didnt see any.
Any Ideas?
Old 07-21-2012   #2
scottfab
scottfab's Avatar
Default Re: Electrical Short.
Any Ideas?
I would expect 12v doing what you're doing even with no short.
Scott
Old 07-21-2012   #3
cvette98pacecar
Where would the live circuit be? The ignition is off and all of the fuses are pulled. There should be no circuit unless there is a short.
Old 07-21-2012   #4
vilant
I know on the 1990 " there is a fuse holder located behind the instrument panel, below and to the right of the glove compartment. To access the the fuse holder, you must remove the cover under the instrument panel on the passenger's side." That's straight from the owner's manual with a pic and an arrow pointing under the glove box. Hope that helps.
Old 07-21-2012   #5
Demps
Demps's Avatar
Check amperage for a current draw, vs voltage. That will show if there's a parasitic draw. There should be a small bit for powered items with key off.
Ted
Old 07-21-2012   #6
VetteMed
Yep, there's actually 2 fuse holders with 4 fuses in each, if I recall correctly.
Old 07-21-2012   #7
scottfab
scottfab's Avatar
Putting the reason why you'd see 12v on the neg side of the pulled battery wire, why do you think there is a short?
What is the original symptom?
Battery runs down ?
Scott
Old 07-21-2012   #8
cvette98pacecar
Battery runs down ?
Battery is on a tender always and it is dead, The tender can keep up with the drain.
Old 07-21-2012   #9
cvette98pacecar
Ted
That was the next step after checking for a closed circuit, when the circuit should be open.
Old 07-22-2012   #10
Hib Halverson
If you connect a volt meter between the batter and ground it will read whatever the battery voltage is.
If you connect an amp meter between the battery and ground you'll read current flow. There should be only a few hundred milamps.
From reading the other posts, I think you understand the procedure of using either a test light or an ammeter then pull fuses.
You might also have a battery which is, itself, shorted.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
