Old 06-13-2012   #8
scottfab
scottfab's Avatar
Default Re: Stumblin Bumblin Z
Ok, after pouring over this thread I picked up on something.
You say you have 42 lb of fuel pressure and it goes to 50 when you rev up. You should have 50lb or so without reving.
Could be that your secondary fuel pump is intermittent.
If you do some hard accelerations up to the stumble a few times see if a lean code gets set. Then its pretty certain.
I had something very similar but at 4500 rpm. It never set a code.
When I replaced the secondary fuel pump it went away.
My fuel pressure with both pumps whet to 44lb when I just turned the key on. Then it would leak down pretty fast.
When I replaced the pumps it went to 52 and came down very little over time.
You may need to connect a fuel pressure gauge and go for a drive up to the stumble.
Scott
