Old 01-30-2012   #1
Scrrem
Scrrem's Avatar
Default WTB: Fuel Injector Gaskets
I pulled my plenum yesterday and while carefully removing the connectors off of the fuel injectors, I noticed I am missing one of those square gaskets that fit up in the connector for the fuel injector. Can you still get those from GM?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 01-30-2012   #2
Default Re: WTB: Fuel Injector Gaskets
Not sure but if not Marc Haibeck might be able to hook you up
Old 01-30-2012   #3
Scrrem
Scrrem's Avatar
I'll check with him, I have to send him some parts anyway. I checked Jerry's site, didn't see any. It seems like a common part that may still be used in modern cars, GM may still carry them.
Rich
Ron Davis Radiator
Old 01-30-2012   #4
bobbyhi
bobbyhi's Avatar
I lost 2 of them during my plenum pull. I made new ones with gasketing material of the same thickness. Been in there for a couple of years now and no problems. Total cost around $1........use an existing one for the pattern...............
Old 01-30-2012   #5
mike100
You can just swing by the pull-it-yourself wrecking yard and get those same rubber seals out of any bosch style injector plug- just about most of the 90's f.i. out there. 4 cyl, V6, V8.
Old 01-30-2012   #6
Scrrem
Scrrem's Avatar
Cool, that's kind of what i thought. I don't think injector connectors have changed a whole lot over the years. I'll take one with me to be sure.
Rich
Ron Davis Radiator
Old 01-31-2012   #7
4-cam
Or you could order a new plug from Rockauto for a a little over 6 bucks. I would think the gasket would be in a new one. It may not be a bad idea to have a few of these in the spare parts bin anyways
ACDELCO Part # PT2384 {#88862303} 2-WAY FEMALE BLACK
CONNECTOR,INJR-FUEL 2 DOORS; W/CENTERED INDEX SLOT W/RELEASE
4-cam is offline   Reply With Quote
Old 01-31-2012   #8
Scrrem
Scrrem's Avatar
Not a bad idea, think I'll pick one up...Thanks
Rich
Ron Davis Radiator
Old 01-31-2012   #9
VetteMed
I think I've been running without a few of those, I don't think it's likely to be a big deal unless the motor is being washed or otherwise gets very wet.
Old 02-02-2012   #10
Y-me
Sh*t come over here and I'll give you one.
Y-me is offline   Reply With Quote
