Old 01-23-2012   #11
Default Re: An option for spare tire replacement....
this is why i have aaa
Old 01-23-2012   #12
VetteMed
Yeah, I have it too... but, I like to be prepared for the unexpected.
Old 01-24-2012   #13
HAWAIIZR-1's Avatar
Originally Posted by VetteMed View Post
Craig, these kits are shipped with fullsize trucks, specifically the Silverado when equipped with dual exhaust. I figure if it's adequate for a tire with the size and volume as found in a fullsize truck, our 315s shouldn't be a problem.
Okay, thanks. Please send more info about this system if you prefer not to post here via PM or email.
Thanks,
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 01-24-2012   #14
VetteMed,
Please send me an additional info also.
Is the sealant refillable after use? Or is this for one time use only?
Old 01-24-2012   #15
ZR1Vette
ZR1Vette's Avatar
Same idea... ContiComfortKit by Continental and is a system that many Euro GT cars come with (I have for my C6 since I have non run flat tires)>>>
Old 01-24-2012   #16
HAWAIIZR-1's Avatar
Michael,
Thanks. Please share what you might have heard or your experience. When I was going to order the Conticomfortkit, Tire Rack said it would not work for our OEM size tire or my 335/30/18 on the other wheels I have.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 01-24-2012   #17
ZR1Vette
ZR1Vette's Avatar
Michael,
Here is a link to the ContiComfortKit tire application range>>
http://www.conticomfortkit.co.uk/htm...Ktyretable.pdf
Knock on wood, I have had no experience actually using the Conti system but have heard from others that it works as advertised
Old 01-24-2012   #18
HAWAIIZR-1's Avatar
Thanks, that appears the same chart on Tire Rack. I emailed a question to Continental Tire direct with the size to see what their explanation is to the limit of tire size. Not enough sealant I guess?
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 01-24-2012   #19
Tom,
You still use sensors? I thought they come off at high speeds like you drive...........
My car is still stock Craig ...so no they haven't come off yet! But if I buy tires for my OEM wheels I am loosing the sensors.
Personally, after looking at our sensors I don't see how the stuff can get in. The plastic case is fairly tight, and since the out rush of air from a puncture would drag the sealant to it. I just don't see a big chance of fouling our sensors.
Old 01-24-2012   #20
VetteMed
VetteMed,
Yun,
The sealant cylinder is replaceable on its own from GM, but is not refillable as far as I can tell. The compressor can be used without the sealant cylinder -- the instructions state to fill the flat with sealant and air, then drive a few miles, and then recheck pressure and inflate as needed.
I haven't investigated a PN for a replacement sealant cylinder, but I can do so when I get a chance.
-Andrew
