Old 01-13-2012   #1
RHanselman
RHanselman's Avatar
Smile #99 arrived...
I said I post a list of Mod's completed on number 99 as soon as I took inventory. I was going to give it a good once over and report back however it seems the guy recorded everything he's ever done. He provided 4 pages of spreadsheet entries which included all the Mod's, services and maintenance...
Here's his list:
Engine:
368 cid 532 HP at 6750 rpm, 452 ft/lbs torque
J&E forged pistions, file fit plasmy moly rings
Eagle ESP I beam connecting rods, Clevite 77 race bearings
New GM stock race bearings
EA22H inlet camshafts, stock exhaust camshafts custom timed
Custom porting of cylinder heads and injector housings
Phosphor bronze valve guides and Teflon seals
New valve springs with titanium retainers
Matched Siamese plenum with 63 mm throttle body
ZF Industries Prom with 7500 rpm limit
Silicone Hoses
Forced Air intake
DRM Radiator
Exhaust:
Ceramic coated Watson headers
Borla Exhaust
Transmission and rear gears:
W.R.P Short shifter
4.09 Gears (DANA)
Suspension:
Adjustable Coil-overs DRM with revised FX-3 Chip
Bilstein shocks rebuild
Ploy Bushings
30 mm Front sway bar
Chassis:
Roll Bar
Under carriage cross bar
Wheels:
Fikse FM/5 18x10 front 18x12 rear
Brakes:
Front Wilwood 6 piston w/13 inch alu hat rotor
Rear GM 4 piston with wilwood 12 in rotor
Air ducting to front and rear
DRM High volume master cylinder
Brake bias adjustment control (in engine bay) this is what I couldn't identify earlier
Exterior:
Morrison Motorsports ground effects package
Total cost: $41,642
All I have to say is wow... and I'm very
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 01-13-2012   #2
Pete
Pete's Avatar
Default Re: #99 arrived...
Nice
Get rid of the Borla and post up some pictures.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-13-2012   #3
captcorvette
Wow what a great surprise. Now the big question is what else are you planning on doing to it?
captcorvette is offline   Reply With Quote
Old 01-13-2012   #4
Blue Flame Restorations
What a wish list for the rest of us!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 01-13-2012   #5
RHanselman
RHanselman's Avatar
Nice
Pete
Agreed, the Borla needs to go... Will post pics after I wash the travel dirt off...
Do you know the specs for these? EA22H inlet camshafts
Cheers,
Ron
Old 01-13-2012   #6
PhillipsLT5
PhillipsLT5's Avatar
The Police are looking for you, You stole that car!
Old 01-13-2012   #7
Pete
Pete's Avatar
Cheers,
Ron
Last time i had a set of those cams i don't know if they were EA22B or EA22H which ever ones i had i did check them.
The ones i had were .230 pri .240 sec on the lift i will have to double check my files can't remember right now what comes to mind is .400pri 420sec again i will have to double check.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-13-2012   #8
Hey Ron what kind of gun did you use.....just curious & just kidding! What a list on the motor! That reads like a "Who's Who" of sweet parts! The T/Q is a very nice number.
Good Luck and play with her in good health!
Old 01-13-2012   #9
RICKYRJ1
RICKYRJ1's Avatar
That car had been for sale for some time and I should have taken a closer look at it.. That is a lot of car for the $$ Nice pick up Ron!
enjoy and keep us posted on how she runs
Old 01-13-2012   #10
RHanselman
RHanselman's Avatar
Corsa Cat Back... This thing has no CAT's. I forgot what a no CAT car smelled like and I need them for SMOG anyways. I'm also going to hunt down all the SMOG stuff and hook it back to the Watson's. They are pre-plumed for the tubing.
The Borla's are going to go... Anyone interested? I'm also going to sell the B&B's off #140.
