Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Audio/Electronics
Old 12-23-2011   #1
MikeGolf
Default Where is your satellite radio antenna mounted?
Just wondering where the creative minds put theirs. Thank you.
'93 #166 Black Rose
“Out of every one hundred men, ten shouldn't even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them, for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back.” Heraclitus
MikeGolf is offline   Reply With Quote
Old 12-23-2011   #2
efnfast
Default Re: Where is your satellite radio antenna mounted?
Mine was buried in the dash, but the reception was horrible. So, now it is mounted on the defroster outlet, next to the light sensor. Steve
efnfast is online now   Reply With Quote
Old 12-23-2011   #3
years ago when I ran the website for my old corvette club, I received an email about a mount for a cb radio that used the wheel tub area of the cargo area as a mounting point. what about just in front of the roof holder in the cargo area so you can sorta hide it but still get reception
Old 12-23-2011   #4
2ZR1S
2ZR1S's Avatar
That is where mine is and works great. I removed the plastic and mounted under attatching to the metal. You can barely see it.
Jon R. Member #490
1992 ZR-1 Arctic White/Red
2008 Z51 Silver 6 spd (Daily driver)
2ZR1S is offline   Reply With Quote
Old 12-23-2011   #5
my XM / satelite antenna is mounted where my radar detector should be! (the radar cutout of the windshield)
Works very good....
Old 12-24-2011   #6
MikeGolf
Thanks mine has just been resting where Jon has his, so I migbt as well finish the job.
'93 #166 Black Rose
Old 01-02-2012   #7
Jagdpanzer
Jagdpanzer's Avatar
Installed the satellite receiver in place of the stock AM/FM receiver unit located underneath the jack compartment behind the passenger seat. Mounted the nav and sat radio antennas by the rear hatch latch. The antennas have magnetic bases which stick to the steel support brackets underneath the plastic trim piece. The antenna cables where easy to run and reception is excellent at this location. With the hatch glass down the antennas are hardy noticable.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-05-2012   #8
Both my GPS antenna and XM antenna are mounted underneath the center upper dash vent next to the heat load sensor. They are on the left side closest to the Radar cutout. Work great
