Old 10-30-2006   #1
Artic93
Artic93's Avatar
Default normal idle rpm 93 ?
I have and idle of 1100 is that correct?...seems a bit of a fast idle.
jason
Artic93 is offline   Reply With Quote
Old 10-30-2006   #2
jonszr1
jonszr1's Avatar
Default Re: normal idle rpm 93 ?
If your car doesn't have a chip in it its 650. Mark raises it to 800 if you have a light flywheel. Can you lower it by blipping the throttle ?
Old 10-30-2006   #3
Artic93
Artic93's Avatar
no it stayed there all day long....seemed odd to me. I thought this was computer controlled anyway, so I doubt I can have it set lower can I?
Old 10-30-2006   #4
tf95ZR1
tf95ZR1's Avatar
See if a vacuum hose came off the back of the plenum.
Common after backfire and will result in high idle.
Ted
Old 10-30-2006   #5
Artic93
Artic93's Avatar
will check that, no backfire that i have heard, thanks
Old 10-30-2006   #6
jonszr1
jonszr1's Avatar
Acouple of things to ck. The idle air control valve .take it off and see if that passage is dirty. Do you have a service manual ? if you do i believeit gives youhow to ck the throttle cable. also see if the tps voltage is .54 hope that helps.
Old 10-30-2006   #7
Artic93
Artic93's Avatar
I don't have the service manual yet, but I will print this out and take it to my mechanic and have it checked. I'm not a wrencher by any stretch of the imagination LOL
