12-11-2011 | #11 |
Re: Raced a new CTSV wagon
Are you going to route it into the intake as some sort of electric supercharger?
12-12-2011 | #12 |
now that's an idea! Thanks Bob! Actually instead of having the not needed EGR connection removed from the right side header I'm going to use it. I had a BFO and figured why try to make up those A.I.R. tubes that go into each primary pipe. In stead I'll go get some small s/s tubing and make another EGR tube for the left side header and weld check valves to both of them and use them as my air injection fittings. I figured what's the difference, air injected into the exhaust stream to help heat the CATs is all the same.
