Old 12-05-2011   #1
avijay
Default Radiator Drain Question
Getting ready to pull the plenum this weekend to get to my injectors and wanted to know what was the easiest way to drain enough coolant needed to start the project? Do I have to get under the car to do this or is there an easier way to access a drain port from above and move forward? Thx!!!!!
1970 LT-1 - sold
1971 Vert - sold
1972 454 - sold
1996 Grand Sport - sold
1999 C5 - sold
1969 Mustang Mach1 - sold
1991 ZR-1 - sold
2008 Z06 - current
avijay is offline   Reply With Quote
Old 12-05-2011   #2
Default Re: Radiator Drain Question
the rad petcock can be reached from on top. Right side of car down by the short hose that goes to the T-stat housing. Just under or right near the hose, but a bit lower is the petcock.
If you are not pulling the injector housings draining the rad will be more than enough. If you are pulling the I/H's off then just be careful as the level will be right at the head-I/H matting surface. Have some rags handy.
Old 12-05-2011   #3
Draining about a quart should be enough if the plenum is the only thing you re pulling off.At the front right wheel,wheel turned reach down between the wheel and wheel well and you should be able to reach inside a small 1/2 circle guard and reach the petcock.
Old 12-05-2011   #4
avijay
Thanks for the info, I assume this is the draincock I'm looking to access?
Another question, hopefully not too stupid, but do I just simply unscrew (counter-clock) a little or all the way out, what's the proper operation to start the drainage and stop drainage after taking out about a quart or so? Thanks again.
1970 LT-1 - sold
1971 Vert - sold
1972 454 - sold
1999 C5 - sold
1991 ZR-1 - sold
2008 Z06 - current
Old 12-05-2011   #5
sdycke
yes, counter clock wise. A couple of turns should start a flow. A pair of pliers my be necessary for extra GENTLE persuasion if the petcock hasnt been opened in many years. for a faster flow, just gently (by hand) pull the petcock out slightly after a few more turns (when further turning dosent increase the flow). close by hand. and push in first if you had pulled it out. it is always easier to deal with the consequences of too little force (a leak) than too much ( busted petcock, cracked tank). and if using pliers, its best from underneath. me thinks.
sdycke is offline   Reply With Quote
Old 12-06-2011   #6
Because the petcock tends to dribble, it can be messy, even with a catch pan under it - coolant tends to run along the frame rails, etc, across the front of the car. But! A handy shallow (approx 18x30x5") rectangular plastic storage tub (from WalMart) can be laid down with one end under the petcock, and the other end set so the tub is parallel to the radiator, under the frame. That way you'll catch it all, with no mess!
I have a 5 gallon plastic gas can, dedicated to storing and re-pouring coolant. It works out nice.
Now, all that said, once the plenum is off it is an ideal time to drill and tap and plug the TB coolant passages in the IHs. Unless you intend to do a lot of driving at -10F, you'll never need to heat the TB. Then, if ever you need to pull the plenum again (lots of stuff under there) you won't have to fuss with draining, or getting the air out of the system, again. Just a thought!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 12-06-2011   #7
ZR1Vette
ZR1Vette's Avatar
What they said just showing it with a picture (thermostat housing is removed)
Here is the petcock (red arrow) with the thermostat housing installed (just for a point of reference) and the yellow arrow shows the plastic channel that runs under the radiator and this is where coolant will collect and run down across the rails etc. so you need to put a low collector pan under the petcock AND newspaper/rag under the radiator... as said before can get a bit messy.
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 12-06-2011   #8
Jez Mike, I don't know between you and Ricky I should just let them come and take my car for neglect unbecoming a Z owner in good standing!
That is some kind of clean I can't describe! Kudos to ya!
Old 12-06-2011   #9
ZR1Vette
ZR1Vette's Avatar
Thanks Tom... but Ricky has me beat with his powder coating of the tranny/bell housing and eye candy mods
Michael
:cheers:
Old 12-06-2011   #10
avijay
Great pic, thx! It's pics like that, that make these jobs so much easier.
1970 LT-1 - sold
1971 Vert - sold
1972 454 - sold
1999 C5 - sold
1991 ZR-1 - sold
2008 Z06 - current
