Old 11-28-2011   #1
Corbusa
Default When I got out of the vette I noticed
A little tear on the drives side of the seat where the seat controls are at . Its about a 1/4 inch , but enough to make me say s*it. I guess this is a normal wear point for a 20 + year old car.. Would you trust a standard upholstery shop? I am trying to keep the car as perfect as I can until I get'er paid for , then do any and all the customising..
Oh and 2 other questions, Has anyone here used the rear window drain kits? ( where you drill for drain tubes to be put in the corners of rear windows )
and do they make a setup ( plug and play) to use the CD in the car without need of the antenia being raised ? ( why GM didnt put the antenia in the winshield I'll never know). duh Thanks
Old 11-28-2011   #2
bobbyhi
bobbyhi's Avatar
Default Re: When I got out of the vette I noticed
I put the drains on my '90 and they work very well. I'm sure the NCRS boys would have a fit but mine is not stock anyway....
Old 11-28-2011   #3
Daniel_Mc
Daniel_Mc's Avatar
The previous owner installed the drains on our 89 and they work fine when I wash the car however I couldn't tell you about rain
I took the 89 (far from stock) to a NCRS event with a buddy of mine. Before I left I ask them what I won... They were not amused
Daniel
Old 11-28-2011   #4
oricale
Yeah I installed them on my 96' Grnsprt and they worked
Great. I probably will install them on my Z as well.
oricale is offline   Reply With Quote
Old 11-28-2011   #5
one of the major parts houses has the antenna thing...can't remember which one
Old 11-29-2011   #6
cvette98pacecar
That would work great for a piece of crap I-pod/MP3 adapter on the stock radio.
Why someone doesn't come up with a kit that you would plug into the antenna adapter is just beyond me. Maybe it is time to by a aftermarket head unit and install it is the beast.
Old 11-29-2011   #7
Mystic ZR-1
Mystic ZR-1's Avatar
Forget the drains, why put more holes in your car? Just swipe your wife's turkey baster when she's not looking, works great!
Old 11-29-2011   #8
love this idea....well not taking the wifes...I don't want it up my tail sideways...but buying my own should work...why did i never think of this before? i already use a spatula to clean the windshield
Old 11-29-2011   #9
USAFPILOT
USAFPILOT's Avatar
I have a permanent garage turkey baster now because I kept using it to R&R brake fluid etc.
Old 11-29-2011   #10
PhillipsLT5
PhillipsLT5's Avatar
I have a switch on antenna to stop it from going up/down or you can leave it as factory
