Old 11-09-2011   #1
ammrpm
ammrpm's Avatar
Default FS: Pressure plates
I have 2 used pressure plates for sale. All parts are located in Houston, Tx.
1. Centerforce pressure plate - less than 16k miles, good condition.
$75 +shipping +paypal fees.
2. Factory ZR-1 pressure plate - from a 94 ZR-1 with approximately 35k miles on it, good condition.
$50 +shipping +paypal fees.
Aaron
ammrpm is offline   Reply With Quote
Old 11-10-2011   #2
tf95ZR1
tf95ZR1's Avatar
Default Re: FS: Pressure plates
Why did you take them off?
Old 11-10-2011   #3
ammrpm
ammrpm's Avatar
The Centerforce pressure plate was taken off when it was discovered that the clutch disc was bad. My wife bought me a new pressure plate and clutch disc as a present. So that went on instead of just replacing the disc.
I got the factory pressue plate when I purchased some other parts from a member. This pressure plate was taken off when a fidanza aluminum flywheel swap was done.
Old 11-10-2011   #4
batchman
Any chance you can tell which one is lighter?
Thanks,
- Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's
DRM chip/Watson/Borla/lid/LW batt&headlights,
springs, shocks, pads & lines, quick rack & Turn One,
camber brace, 32/22mm sways, A/C halfway deleted
17x11 & 12 CCW's, 315 & 335 Hoosier A6s
[/I]
Old 11-10-2011   #5
ammrpm
ammrpm's Avatar
batchman - they both weigh a little over 16 lbs. If there is a difference it is less than 1/2 lb.
Aaron
